SP Racing Torque Monster Turbo Kit
Lee P
 Share
Selling on behalf of a customer
Sound Performance Torque Monster Turbo Kit
This kit does exactly what it says.
It has covered around 6000 Miles but the turbo has only done around 1000 miles
It used to have a Quick Spool Valve but this has been removed
It consists of:
PT6766 CEA DBB Turbo
Torque Monster Cast Manifold, heat coasted black
Precision 46mm wastgate
SP 4" DP heat coated black
SP 4" MP heat coated black with 2 bolt adapter flange
Recirc Wastgate Pipe
Oil feed and return lines
Intake pipe with K&N Filter
Black intercooler pipe work with SQV flange to suite greddy front mount
DEI T4 Turbo Blanket
With the correct supporting mods the kit did:
807hp @ hubs
692ftlbs
This was at 2bar of boost with a 50% mix of ethanol
We took it to 1.7 bar on pump fuel and the 2 graphs are overlaid.
654hp @ hubs 1.7 bar pump
590ftlbs
Full details are here including the build thread the kit came from.
http://www.mkivsupra.net/vbb/showthread.php?298266-Kim-s-SRD-Billet-6766-Torque-Monster-Build/page8
http://www.spracingonline.com/store/viewproduct.php?id=3256
http://www.spracingforum.com/forums/showthread.php?468-Product-Release-SP-Racing-Torque-Monster-Turbo-kit-for-93-98-MKIV-Supra
Price is £2000 plus delivery
  • 2 weeks later...
  • 3 weeks later...
Would be great on a VVTI as spool would be very good
On stock engine and cams it would be good for around 650hp
With supporting mods of ECU, fuel system, exhaust, intercooler
What would that be like on a standard VVTi car?
With supporting mods would be required?
Injectors
Fuel lines/pump
ECU - piggyback or standalone
Cams?
could be interested. would be going on a low mileage vvti.
just out of interest - did u see the car when it had the quick spool valve? any idea why this was removed as it was something i was looking into...
Yeah we built the car with the quick spool valve on originally.
The valve failed after a few thousand miles, they don't like the heat
We don't advise running them tbh
On a Vvti you won't need it, the spool will be much better anyway
  • 2 weeks later...
 Share
