Auto box or torque converter knackered??????
Guest Oldschoolrules
 Share
Hi All,
I've got a NA-T with a T61, just had it mot'd etc so ready for summer!! Or not!!!!
Basically after driving it for about 2-3 minutes and its warmed up it stops going past second and needs revving to about 4000 revs to go anywhere!!!! When I got it the fluid level was low so changed the filter and put new fluid in to the correct level. Any ideas as I thought it would be the box but local guy has said it sounds like torque converter!!!
Any help would be much appreciated!!
Hi Chris,
Thanks for the help, will the twin turbo auto box fit into the normally aspirated car?? Presume theres more relays/solenoids??? Also is the TT converter stronger and will that also fit my flywheel????
Cheers mate
 Share
