Ady Posted November 20, 2007 Share Posted November 20, 2007 Took the car out on the weekend (yes, with no bumper) and took her for a nice good thrashing. the break pedal seems to be a bit soft - too soft for the spead the car can actually do - im not shure if its me, the car or both. Im replacing the break fluid soon, and will be getting some braided hoses. Has anyone had any dealings with the goodbridge kits on fleebay? http://cgi.ebay.co.uk/Toyota-Supra-JZA80-Goodridge-Brake-Line-Kit_W0QQitemZ180178842459QQihZ008QQcategoryZ10428QQssPageNameZWDVWQQrdZ1QQcmdZViewItem If this dosent help, i will be going for the clamp that goes onto your strut bar and onto the master cylinder to help reduce the flex. The pads and disks are ok , as they passed with over 85% on mot Cheers Link to comment Share on other sites More sharing options...
Thorin Posted November 20, 2007 Share Posted November 20, 2007 Has anyone had any dealings with the goodbridge kits on fleebay? http://cgi.ebay.co.uk/Toyota-Supra-JZA80-Goodridge-Brake-Line-Kit_W0QQitemZ180178842459QQihZ008QQcategoryZ10428QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Can't view ebay from work, but as it's ebay it's quite possible they're copies. Not that that should matter as there's not exactly much to them, should be fine. Put some decent fluid in too, Motul for example. Link to comment Share on other sites More sharing options...
Ady Posted November 20, 2007 Author Share Posted November 20, 2007 Can't view ebay from work, but as it's ebay it's quite possible they're copies. Not that that should matter as there's not exactly much to them, should be fine. Put some decent fluid in too, Motul for example. I am - dot 5.1 - there S/S braided lines, with a zinc ends so guaranteed for a life time, bla bla bla Link to comment Share on other sites More sharing options...
movistar Posted November 20, 2007 Share Posted November 20, 2007 Power bleed the system when you change them ...has it got abs? Link to comment Share on other sites More sharing options...
markrzs Posted November 20, 2007 Share Posted November 20, 2007 Ady, I bought some braided hoses from a guy on Ebay and fitted them the other week and what a difference ! Go for it Link to comment Share on other sites More sharing options...
Ady Posted November 20, 2007 Author Share Posted November 20, 2007 Ady, I bought some braided hoses from a guy on Ebay and fitted them the other week and what a difference ! Go for it Wich ones were they mate - have you got a link or the sellers ID? Link to comment Share on other sites More sharing options...
Ady Posted November 20, 2007 Author Share Posted November 20, 2007 Power bleed the system when you change them ...has it got abs? Yes i will be doing it in a garage - so i can power bleed it Im not shure if a Stock 94 plate has abs??? Link to comment Share on other sites More sharing options...
ellis Posted November 20, 2007 Share Posted November 20, 2007 Brake!!! Link to comment Share on other sites More sharing options...
Nic Posted November 20, 2007 Share Posted November 20, 2007 Which brakes do you have fitted? The smaller 2 pot front 1 pot rear or the larger 4 pot front 2 pot rear? If you're not sure pots pics so we can identify. Link to comment Share on other sites More sharing options...
miko_supra Posted November 20, 2007 Share Posted November 20, 2007 Which brakes do you have fitted? The smaller 2 pot front 1 pot rear or the larger 4 pot front 2 pot rear? If you're not sure pots pics so we can identify. they look like the smaller brakes to me Link to comment Share on other sites More sharing options...
Ady Posted November 20, 2007 Author Share Posted November 20, 2007 Which brakes do you have fitted? The smaller 2 pot front 1 pot rear or the larger 4 pot front 2 pot rear? If you're not sure pots pics so we can identify. 2 pot fronts and 1 pot rear Link to comment Share on other sites More sharing options...
Guest mk47 Posted November 20, 2007 Share Posted November 20, 2007 hey i am sure the zinc ones are not as good as the stainless steel tipped ones - ive read this numerous times that the zinc ones corrode but the s/s ones are better and are slightly more expensive (both by goodridge) Link to comment Share on other sites More sharing options...
Paul Whiffin Posted November 20, 2007 Share Posted November 20, 2007 That is correct the zinc ones corrode and are a tad cheaper than the stainless steel, personally I only stock the stainless steel versions, dont want to be cutting corners with brakes.... Link to comment Share on other sites More sharing options...
Nic Posted November 21, 2007 Share Posted November 21, 2007 Check how much the brake master cylinder flexes, with engine running get someone to press the brake pedal and you will be able to see the master cylinder moving. A combination of good quality braided brake lines, brake fluid, a good set of pads and a brace for the master cylinder (either Cusco or Carbing brace) should make a significant difference in pedal feel and bit of the brakes. Link to comment Share on other sites More sharing options...
Ady Posted November 21, 2007 Author Share Posted November 21, 2007 Cheers lads - am getting onto this now Link to comment Share on other sites More sharing options...
