halllon Posted November 3, 2007 Share Posted November 3, 2007 Hi all, I am currently involved in the build of a JDM MKIV drift car, and I have come across this excellent forum in my search for information regarding the car. We would like to raise the final gear ratio of the car, and I would be thankful if someone one here could fill me in with following information: What are the most viable way to get a ~ 4.0:1 ratio (or similar)? I have read that NA MKIVs have a 3.7 diff ratio, and auto Aristos have 4.27. Are these diffs the same physical size as the TT diff, and can they take the same power and grip levels? Could Soarers or Toyota trucks be potential donors? Regards, halllon Link to comment Share on other sites More sharing options...
Scooter Posted November 3, 2007 Share Posted November 3, 2007 I'll have a look around for actual ratio figures but the late 6 speed na's have a higher ratio diff Click here for a thread about some conversions where its been used with a TT engine.... Link to comment Share on other sites More sharing options...
halllon Posted April 15, 2008 Author Share Posted April 15, 2008 Is it correct that all 6 speeds have the same size diff casing, meaning that the crown wheel and pinion of a late NA will fit a TT? Will Aristo and early MKIV SUpra NA diff ratios fit the big TT diff casing? Link to comment Share on other sites More sharing options...
edge Posted April 15, 2008 Share Posted April 15, 2008 This may help http://www.mkivsupra.net/vbb/showthread.php?t=29830 Link to comment Share on other sites More sharing options...
JamieP Posted April 15, 2008 Share Posted April 15, 2008 Is it correct that all 6 speeds have the same size diff casing, meaning that the crown wheel and pinion of a late NA will fit a TT? Will Aristo and early MKIV SUpra NA diff ratios fit the big TT diff casing? Na diff will fit but it wont last 2 min. Link to comment Share on other sites More sharing options...
Nic Posted April 16, 2008 Share Posted April 16, 2008 Is it correct that all 6 speeds have the same size diff casing, meaning that the crown wheel and pinion of a late NA will fit a TT? The Supra was fitted with 2 diff casings. The black one in the pics below was fitted to all the early model (93-96) manual 6spd TT Supras. The other smaller diff casing was fitted to every other Supra model (late model manual TT, NA, auto). Do you know which diff casing you have? http://img442.imageshack.us/img442/343/supravsoarerjw5.jpg http://img170.imageshack.us/img170/571/supravsoarer2sc5.jpg Toyota sell the final gear sets, I've recently supplied one to a member who was wanting a longer gear ratio. http://img176.imageshack.us/img176/6451/picture1oh4.png Link to comment Share on other sites More sharing options...
halllon Posted April 16, 2008 Author Share Posted April 16, 2008 Cheers, thanks for your information. My diff is a VVTi differential, and it's definitely the smaller one. How much is a higher ratio, such as a 4.27 or higher (I don't know what's available), shipped to Norway? Link to comment Share on other sites More sharing options...
Nic Posted April 16, 2008 Share Posted April 16, 2008 Cheers, thanks for your information. My diff is a VVTi differential, and it's definitely the smaller one. How much is a higher ratio, such as a 4.27 or higher (I don't know what's available), shipped to Norway? Available ratios to fit your diff are Auto & 5spd Manual NA - 4.083 Auto TT & 6spd Manual NA - 3.769 Manual late model TT - 3.266 Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 16, 2008 Share Posted April 16, 2008 Morning Halllon. May I draw your attention to this used but excellent diff I have? : http://www.mkivsupra.net/vbb/showthread.php?t=141916 I also have a complete set of new side bearings and side seals to enable a TRD plat type LSD to be fitted to it. I would like 120 UK ponds for the diff itself, shipping is unknown, it's heavy old lump. Link to comment Share on other sites More sharing options...
Wez Posted April 16, 2008 Share Posted April 16, 2008 I also have a complete set of new side bearings and side seals to enable a TRD plat type LSD to be fitted to it. Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 16, 2008 Share Posted April 16, 2008 I am trying for you Wes, i really am (Wes has some new bearings and seals here, that I said I'd try and find a buyer for...). Link to comment Share on other sites More sharing options...
halllon Posted April 17, 2008 Author Share Posted April 17, 2008 Hi Guys, Thanks for your offers. I have just bought a TRD LSD, new seals and bearings for my diff, so ideally I only need the crown wheel and pinion... Any chance you could split the diff and sell the parts separately, Wilson? On another note - will this smaller diff take the abuse in a fairly light drift Supra? We'll be running low power, around 450hp/550nm, but grippy R888 tires. Link to comment Share on other sites More sharing options...
Wez Posted April 17, 2008 Share Posted April 17, 2008 Why would you use R888s for drifting? Link to comment Share on other sites More sharing options...
Ian Hayward Posted April 17, 2008 Share Posted April 17, 2008 You may find this useful (a little speadsheet my mate knocked up): Difference between 6 speed NA and TT diff ratios and the gear speeds. You can also adjust some of the cells to show you how different ratios will workGearbox Calculator V1.xls Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 17, 2008 Share Posted April 17, 2008 Sorry, only want to sell as a unit. Being built up will allow you to do a cheap intall of your kit, as it will need minimal shimming as the pinion bearing won't be disturbed. Link to comment Share on other sites More sharing options...
