2jzgte injectors same as n/a injectors
Guest gareth - track
Can anyone tell me if n/a injectors will fit a 2jz
I just want to know if there fit or not? Been offered some big cc injectors but there from a n/a engine :rolleyes:
  • 8 months later...
Guest kponx
I think supra 2JZ-GTE is the twin turbos...and 2JZ-GE is the NA..Just add the info to let u know guys...cheers..
Are you intending to go single turbo e.t.c?
There is no need to go higher than the US/UK spec 550's if your not, if you wish to keep the stock fuel rail then I'm sure there are 720's that drop straight in, but as mentioned are not needed for bpu
You also have to take into account what type of injectors they are if you are intending a management system(ecu) to control them, i.e. low impedance/high impedance
Lastly, if you do buy them I'd advise getting these injectors flow tested, you dont want to drop them in and find you've blown a nice hole in your piston because one has stopped working or has picked up debris in transit, better to be safe than sorry;)
Flow testing is around 100-120quid on top
