Ark Posted August 30, 2007 Share Posted August 30, 2007 Just toying with an idea here, but do any of the turbo kits currently on the market use internal wastegates? I like the idea because there is less plumbing to fix up, and no noisy screamer pipes to get you booted off track. Oh, and with lower boost levels and lower power aspirations, don't internal wastegates allow more accurate control? Link to comment Share on other sites More sharing options...
Ian C Posted August 30, 2007 Share Posted August 30, 2007 Nope. Only dinky OEM turbos have integrated wastegates. You can blend the screamer pipe back into the exhaust if you wish, just do it at a shallow angle, about 2 to 3ft back from the turbo, and put a flex section in it. -Ian Link to comment Share on other sites More sharing options...
Gaz Walker Posted August 30, 2007 Share Posted August 30, 2007 The biggest turbo with a internal wastegate is a GT28, so not going to make much power on a Supra Gaz. Link to comment Share on other sites More sharing options...
Muffleman Posted August 30, 2007 Share Posted August 30, 2007 And if you start running high boost, you might run into creep if the wastegate is too small. As Ian says, plumb the vent pipe back into the exhaust. Link to comment Share on other sites More sharing options...
Ark Posted August 30, 2007 Author Share Posted August 30, 2007 Shame. I still think it's a bit odd that there are no kits that plumb the screamer into the downpipe out of the box. Link to comment Share on other sites More sharing options...
Alex Posted August 30, 2007 Share Posted August 30, 2007 Shame. I still think it's a bit odd that there are no kits that plumb the screamer into the downpipe out of the box. They cost more to produce so they don't bother as there's limited take up. It's not hard to get a section fab'd up. Link to comment Share on other sites More sharing options...
Gaz Walker Posted August 30, 2007 Share Posted August 30, 2007 Sound Performance still make kits with wastegates piped into the DP... Gaz. Link to comment Share on other sites More sharing options...
Nic Posted August 30, 2007 Share Posted August 30, 2007 The GT30R and GT35R are both available with optional internal wastegate. Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 30, 2007 Share Posted August 30, 2007 Shame. I still think it's a bit odd that there are no kits that plumb the screamer into the downpipe out of the box. I agree, but with a bellows section to handle differential expansion it shouldn't be too hard to do. Link to comment Share on other sites More sharing options...
Nic Posted August 30, 2007 Share Posted August 30, 2007 Shame. I still think it's a bit odd that there are no kits that plumb the screamer into the downpipe out of the box. Most of the Japanese kits plumb the wastegate back into the downpipe, it's just the US kits that seem to prefer screamer pipes. with a bellows section to handle differential expansion it shouldn't be too hard to do. I really want to get mine plumbed into the downpipe, as the screamer pipe just causes to much attention here. Do you have any photos Chris showing an example of what you mean? Link to comment Share on other sites More sharing options...
Ark Posted August 30, 2007 Author Share Posted August 30, 2007 Most of the Japanese kits plumb the wastegate back into the downpipe, it's just the US kits that seem to prefer screamer pipes. Can you elaborate on that please Nic - the usual three brands (HKS, Blitz and Greddy) all use generic photos which seem to show screamers... Link to comment Share on other sites More sharing options...
Nic Posted August 30, 2007 Share Posted August 30, 2007 Can you elaborate on that please Nic - the usual three brands (HKS, Blitz and Greddy) all use generic photos which seem to show screamers... The HKS T04Z and T51 kits I've seen plumb the wastegate back into downpipe. Pic here, not sure which kit it is specifically, but you can see on the downpipe, the pipe coming off to connect to the wastegate. http://www.hks-power.co.jp/products/turbo/turbinekit/waste_sp/img/waste_sp_image.jpg I think you're right about the GReddy T78 and T88 kits, it does look like they use a screamer pipe. Blitz no longer sell a kit for the Supra. Link to comment Share on other sites More sharing options...
mikeyb10supra Posted August 30, 2007 Share Posted August 30, 2007 The biggest turbo with a internal wastegate is a GT28, so not going to make much power on a Supra Gaz. would do if you had two of em Link to comment Share on other sites More sharing options...
SupraPL Posted August 30, 2007 Share Posted August 30, 2007 Is any difference in efficiency between turbochargers with a internall and externall wastegate? Link to comment Share on other sites More sharing options...
Gaz Walker Posted August 30, 2007 Share Posted August 30, 2007 The HKS T04Z and T51 kits I've seen plumb the wastegate back into downpipe. Pic here, not sure which kit it is specifically, but you can see on the downpipe, the pipe coming off to connect to the wastegate. The big twin kit also goes into the DP too Link to comment Share on other sites More sharing options...
Darren Posted August 30, 2007 Share Posted August 30, 2007 Sound Performance still make kits with wastegates piped into the DP... Gaz. Theres one on Supraforums (SP bubget kitinternal wastgate) $1000 at moment..Cheap as...Was thinking about buying it myself £500 Link to comment Share on other sites More sharing options...
