JonW Posted August 10, 2007 Share Posted August 10, 2007 Did a brake fluid change yesterday and the two rear rubber bleed nipple covers fell apart. How important is it to have these in place and is it possible to buy them? Also if anyone is interested I used a piece of tubing bought from Halfords that had a non return valve on it. This meant that I could bleed the system myself but without the need for tyre pressure and a seperate reservoir of brake fluid. It cost around £5. Cheers Jon Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 10, 2007 Share Posted August 10, 2007 Not important really, I wouldn't worry about them. I think you can buy the from Toyota if it bugs you, though. Link to comment Share on other sites More sharing options...
Kranz Posted August 10, 2007 Share Posted August 10, 2007 Just slip a bit of hose over all the way down and fill the top with silicone. Better than the original (as it'll stop the threads corroding) and £0.00 if you already have the bits Link to comment Share on other sites More sharing options...
SamuraiFlash Posted April 30, 2012 Share Posted April 30, 2012 Hi, can someone please tell me the part number for the bleed nipple covers for UK spec rear calipers. Thank you. Link to comment Share on other sites More sharing options...
David P Posted April 30, 2012 Share Posted April 30, 2012 32b Link to comment Share on other sites More sharing options...
Dnk Posted April 30, 2012 Share Posted April 30, 2012 (edited) They come in the caliper seal kit from Toyota and not sure you can buy them on their own. Try your local motorfactors as these will be the same as a lot of other cars. As said a bit of rubber hose is the way to go and silicon the end If the bleed nipple covers fell apart i'd have a close look at the piston outer seals, unless they have been changed they could also do with being replaced before they split and then you end up with seized pistons Edited April 30, 2012 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
SamuraiFlash Posted April 30, 2012 Share Posted April 30, 2012 Oh bugger, I'll just stick some silicon tubing on then. I need them for my new UK calipers, they didn't come with the bleed nipple covers for some reason Link to comment Share on other sites More sharing options...
Dnk Posted April 30, 2012 Share Posted April 30, 2012 Oh bugger, I'll just stick some silicon tubing on then. I need them for my new UK calipers, they didn't come with the bleed nipple covers for some reason Pop into your local carspares shop, bleed nipple covers on most calipers will be the same Link to comment Share on other sites More sharing options...
SamuraiFlash Posted April 30, 2012 Share Posted April 30, 2012 Ok Dunk I'll try that, thanks btw I'm going to see Simon on Thursday, try and pop round if you can. Link to comment Share on other sites More sharing options...
Dnk Posted April 30, 2012 Share Posted April 30, 2012 Ok Dunk I'll try that, thanks btw I'm going to see Simon on Thursday, try and pop round if you can. What time are you there ? Link to comment Share on other sites More sharing options...
SamuraiFlash Posted April 30, 2012 Share Posted April 30, 2012 I'll be there for 2pm Link to comment Share on other sites More sharing options...
