Brake Pad Question
Bobbeh
As posted in other thread.. just incase it wasnt seen:
My friend was suggesting that the 2 shims could cause uneven wear on the piston seals due to the gap on that half moon shape, and it would be best not to use them or only use one.. my thoughts were leave it how toyota had intended but he was pretty adament it wouldnt make the blindest bit of difference if they werent in there.
What do you think? :conf:
Just did my front pads on Monday and this never occured to me. But I agree with your reasoning that if Toyota designed it this way then they should be okay.
My pads had a full shim covering the whole pad and on top of that was the one with the half moon shape.
Not sure if the diameter of the half moon shape of the shim is the same size or larger than the diameter of the piston anyway.
What I mean by the moon shape is that the piston is round right? and when it hits the shim half the circle his the half moon shape and presses the pad.
His point was, was that the 2 shim plates made the drop on contact uneven and could cause damage to the seals?
I dunno, i just wanted it left as it was. :) I am not doubting what he was suggesting, just wanted some other thoughts about it.
Dude,
Sorry for not replying in the other thread!! I agree with you mate - leave it as it is - The supra brakes are not notorious for having problems, and they are all getting on a bit now. I guess if it did cause a problem, it would have shown by now in a good few cars. I can see what your mate is saying though.
Yep I already knew what you were getting at, but I didn't measure the dia of the half moon cut-out on the shim . Does the piston push against the shim and the backplate of the pad or is it larger than this and only pushes against the shim.
I'm sure there is good reasoning behind the design.
I think half presses against the shim and half presses the pad, hence the drop you'd get with the 2 shims in place.
Originally posted by Ian C
I run no shims, it made an unbelievable (positive) difference to the brake pedal feel and zero impact on brake squealing. YMMV :)
-Ian
Yeah, this is what he was going on about, makes you wonder why Toyota put them in then?! :)
I'm running no shims but I have the KAD setup front and rear. I agree that it will improve pedal feel a great deal but some people say it causes squeal but I think that has more to do with the pads you use.
My only complaint is a slight rattle on the rears with no shims...:thumbs:
Cheers
