Roll Cages
Wez
Hey All,
What to get and where to buy it from?
Does anyone have one fitted and can share pics and experiences.
Are they easy to install, could I do it myself?
:cool:
They are relatively easy to fit just drilling and bolt together, some modification to trim/carpet would be needed.
4 or 5 point Carbing rear roll cage, there is a certain HK trader on the forum I believe who can supply them :hide: :dontfeedmods:
http://www.okuyama-go.to/products/carbing/index.html
Cant read that but looking at number 10, 12, 13 and 14 images.
How much do these cost and are they Supra fitment or do I have to cut to size?
They are specifically designed to fit the Supra.
If you are wanting a full cage, then best to buy locally, as postage would be expensive from here for the bigger ones.
I seem to recall CW's view on roll cages being along the lines of they're relatively useless unless they're welded in.
that's not to say that a bolt in jobby won't do ANYTHING, perhaps just that it wouldn't justify the cost?
if Paul Whiffin has one perhaps he can enlighten us as to whether it has made a difference or not.
My insurance company said my premium would rise if I fitted a roll cage. Don't really understand that
i think it's something to do with restricted access for passengers as well as the fact they may knock themselves out on it in the event of an impact etc. etc.
nice to see you on here Alan by the way, hope you had a good festive season and hope you have a better 2007 :)
The mounting points for even bolt in cages need welded on reinforcements otherwise they will just punch through the thin steel of the bodyshell. As this makes a mess and needs painting you might as well weld the thing in. There are roll cages and there are bling bits of bent tube... If you intend to ever use the car for RAC MSA sanctioned events you need a certified cage, fitted by certified fitters.
My car came from Japan with a 6 point cage bolted in, but i couldnt get in the damn car within 3 minutes, use the sun visors, use the rear seat, see very well out the back :p
I took it out!
Im currently thinking of removing my rear seats (never met anyone who could sit in them without complaining!) having a small rear cage and harnesses.
My car came from Japan with a 6 point cage bolted in, but i couldnt get in the damn car within 3 minutes, use the sun visors, use the rear seat, see very well out the back :p I took it out!
I saw your car when it was in Jurgen's garage.. I was after a cage at that time - ended up buying one of ebay for 400 quid, bolt in... it was padded and I covered it in black alcantera - looks discreet and no one really notices. It comes come out pretty quick too if needed.
a family request more than my own, but every supra I have seen roll so far has had a lot of a pillar damage. Now I come to think of it the base would probably punch out of the floor.. it's is not strong, but it offers more protection than stock though.
They are a pain to get in and out of, and sat in the car there is not much room for a helmet.. but I like it, have got used to it...
but it keeps the girlfriend and family happy..
wez - you'll see it at donnington.
forgot to add - when you pull out over steep kerbs and the like you can hear it move against the body of the car as the apolstery changes position. I never really realised how much cars twist until having one. Getting it welded in all over would help stiffen, but I don't fancy getting the blowtorch out.. would make a difference on a stipped track car though I recon...
Chris, any ideas where I could source the parts locally to fit myself, we have a welder etc so just need the parts.
By pads I mean metal plates welded onto the ends of the tube that act as feet to spread the load, so the tube ends don't act as spears to punch through the floorpan. These pads bolt onto, or weld onto, pads welded to the floorpan of the car, so as to make a sandwich construction speading the loads in the event of a crash.
CDS is cold drawn seamless. Seamed tube is weak, CDS is strong and made to a high standard.
