Very slight engine knock ???
markjodrell
Firstly I have been reluctant to post this as ignorance is bliss so head in the sand trick.:( :(
However , bite the bullet and ask this question.
I have noticed, on tick over, there is a slight knocking noise coming from the engine, if I put the minimum revs on the noise vanished and otherwise is sweet as a nut, its just there on idling, it doesnt always do it but it is there sometimes.....
Could this be the start of a big end bearing going ????
What are the classic signs of big ends failing, and how can I test for it ??
the car only has around 68Kms ( alledgedly) :(
Knocking or ticking? Sure it's not the injectors? They tick at a level that is audible at idle....
You know what noises are like , hard to describe, I recognise the injector ticking but this is more like a slight knock, but as I said if I rev it "very" slightly it goes and cannot be heard when driving at all under load , I may be paranoid.
When it's been out in the cold all night, the oil will be cold a thicker and take longer to move, therefore if the noise is worse at this point you can pretty much be sure that it is related to a moving (requiring oil) part within the engine. If it is the same then it MAY not be as bad as you are thinking.
I cannot hear any knocking when its cold. I have noticed what sounds like maybe the water pump is a bit squeaky/squeely when its cold but that goes off when its been running a while.
I havne really drove the car much over the past few weeks since I got it as I have been working away. I started it yesterday for the first time in 5 days and just let it tick over until warm, mainly just to keep it going. I might be paranoid but you know what its like when you buy a car , always listening for the worst.
Would a big end noise go when you rev the engine, I would have thought the knocking would get faster, any ideas
I have read on here that Chris Wilson is a top bloke, does he have a garage and is he open on Saturdays.
I would imaging someone like Chris could tell what this noise was by having a listen , obviously any remedial work would be done by him ( funds permitting )
Is he an approachable guy or would the car have to be booked in etc etc :search: :search:
Anybody have his business address ??? I know he is in Shropshire somewhere
See my sig, I can have a listen whenever you like, within reason. E-mail or phone me though, PM's tend to get ignored. Thanks.
Cheers Chris,
I am working in Newbury till Fri afternoon, I live in Stoke-on-trent,
where about are you? near Market drayton ???
Are you open on Saturdays ?
If you would prefer to give details out over the phone I can give you a call on Fri afternoon when I get home
cheers
Mark
I have visited Chris today and he has said that the noise is basically tappit/injector so nothing to worry about.
Looks like there could be a decat on the cards :) :)
Top fella who really knows his stuff, quite handy behind the wheel too with the traction control off on a wet road [sHOCK][/sHOCK]
Big thanks for your time Chris :)
