rpslaughter1982 Posted December 2, 2006 Share Posted December 2, 2006 I've recently purchased a PHR street turbo kit and I'm in the process of getting all the parts to complete the install. I want to replace the injectors (jap spec). I'm just about to purchase some SARD side feed 650cc injectors but thought I would run it passed the experienced members for approval first! Will the SARD injectors be OK and does anyone have any opinions on them. I'm also thinking of getting the ENVY double decat pipes, any opinions on these? Any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
Homer Posted December 2, 2006 Share Posted December 2, 2006 Can't tell you much about the Sard's though I was warned they're a budget make so possibly not 'the best' available. Make sure you get them flow tested prior to being installed though (same applies to any injectors). You do not need a double decat with a single kit. Your PHR kit should contain a downpipe which replaces the 1st cat pipe on the stock car. You should only need a 2nd cat replacement pipe, Any will do so long as they are 3inch diameter and made of stainless steel. Link to comment Share on other sites More sharing options...
rpslaughter1982 Posted December 2, 2006 Author Share Posted December 2, 2006 thanks for the reply, how do I get them flow tested and how much will it cost? Link to comment Share on other sites More sharing options...
Homer Posted December 2, 2006 Share Posted December 2, 2006 Approach someone like Terry S who can arrange the testing for you. There's places you can go to direct but I don't know any. I think it normally costs around £120 to have a proper test done on all 6 injectors. Link to comment Share on other sites More sharing options...
rpslaughter1982 Posted December 3, 2006 Author Share Posted December 3, 2006 I've ordered the injectors now so fingers crossed they're ok. I'll speak to Terry S when they arrive. Thanks again. Link to comment Share on other sites More sharing options...
Kranz Posted December 3, 2006 Share Posted December 3, 2006 Rich, there's a place I can get them done for you in Shoreham. Failing that Automarine Diesel can do that in Hove. Give me a shout or email at work. Oh, and what fuel controller are you going for??? Emanage ?? Link to comment Share on other sites More sharing options...
rpslaughter1982 Posted December 3, 2006 Author Share Posted December 3, 2006 Cheers I'll give you a buzz when I get them. I'm not decided what ecu device to go for. I'm looking on the e-manage ultimate favourably at the moment, any thoughts? Link to comment Share on other sites More sharing options...
TLicense Posted December 3, 2006 Share Posted December 3, 2006 http://www.injectorcleaning.co.uk/ Link to comment Share on other sites More sharing options...
Rich Posted December 3, 2006 Share Posted December 3, 2006 I've recently purchased a PHR street turbo kit and I'm in the process of getting all the parts to complete the install. I want to replace the injectors (jap spec). I'm just about to purchase some SARD side feed 650cc injectors but thought I would run it passed the experienced members for approval first! Will the SARD injectors be OK and does anyone have any opinions on them. I'm also thinking of getting the ENVY double decat pipes, any opinions on these? Any help would be greatly appreciated. hi mate ,Im sure I heard a few people on here say that the sard injectors had a poor spray pattern.Apparently the ones to go for are the power enterprise 650s.They drop straight in to the J-spec rail but are supposed to have a very good spray pattern.Worth the extra few quid IMO. Link to comment Share on other sites More sharing options...
rpslaughter1982 Posted December 5, 2006 Author Share Posted December 5, 2006 Can anyone tell me what these pipes are for and what I do with them when fitting my single. I can't see where they go to! Link to comment Share on other sites More sharing options...
rpslaughter1982 Posted December 6, 2006 Author Share Posted December 6, 2006 Anyone??? Link to comment Share on other sites More sharing options...
JustGav Posted December 6, 2006 Share Posted December 6, 2006 I think either engine coolant or gearbox cooler pipes, hard to tell from the picture to be honest. Link to comment Share on other sites More sharing options...
rpslaughter1982 Posted December 6, 2006 Author Share Posted December 6, 2006 Is this one any clearer? It's at the back of the block Link to comment Share on other sites More sharing options...
JustGav Posted December 6, 2006 Share Posted December 6, 2006 Ah yes, that is a lot clearer... Those I believe are pipes which are used with the VSVs and assorted boost pipes, the hard pipes should go round the back of the block to a pressure tank. Link to comment Share on other sites More sharing options...
RobSheffield Posted December 6, 2006 Share Posted December 6, 2006 Those I believe are pipes which are used with the VSVs and assorted boost pipes Yes they are Link to comment Share on other sites More sharing options...
Ian C Posted December 6, 2006 Share Posted December 6, 2006 I think either engine coolant or gearbox cooler pipes, hard to tell from the picture to be honest. You noob, that was perfectly clear Pressure tank. Don't ask me which hose goes to which barb on the tank though -Ian Link to comment Share on other sites More sharing options...
JustGav Posted December 6, 2006 Share Posted December 6, 2006 You noob, that was perfectly clear Pressure tank. Don't ask me which hose goes to which barb on the tank though -Ian My bad for not actually clicking on the pic and looking at it properly, I just looked at the thumbnail. Link to comment Share on other sites More sharing options...
rpslaughter1982 Posted December 6, 2006 Author Share Posted December 6, 2006 Great thanks for your help. Now another question! What do I do with them?!!? I've read various members turbo build threads but can't find any info on them Link to comment Share on other sites More sharing options...
JustGav Posted December 6, 2006 Share Posted December 6, 2006 Nothing is the easiest answer, take the rubber pipes off and just leave them or carefully fold them closer to the block.. Link to comment Share on other sites More sharing options...
