Help with what parts for install
rpslaughter1982
I've recently purchased a PHR street turbo kit and I'm in the process of getting all the parts to complete the install.
I want to replace the injectors (jap spec). I'm just about to purchase some SARD side feed 650cc injectors but thought I would run it passed the experienced members for approval first!
Will the SARD injectors be OK and does anyone have any opinions on them.
I'm also thinking of getting the ENVY double decat pipes, any opinions on these?
Any help would be greatly appreciated.
Can't tell you much about the Sard's though I was warned they're a budget make so possibly not 'the best' available. Make sure you get them flow tested prior to being installed though (same applies to any injectors).
You do not need a double decat with a single kit. Your PHR kit should contain a downpipe which replaces the 1st cat pipe on the stock car. You should only need a 2nd cat replacement pipe, Any will do so long as they are 3inch diameter and made of stainless steel.
hi mate ,Im sure I heard a few people on here say that the sard injectors had a poor spray pattern.Apparently the ones to go for are the power enterprise 650s.They drop straight in to the J-spec rail but are supposed to have a very good spray pattern.Worth the extra few quid IMO.
