is it safe to use NOS on my n/a?????
supra-lover
Guys,
If you are going to do it, it is by far the cheapest bang for buck....BUT don't be silly and think a 200 shot can be fired straight in without taking the head off....
Anything over a 75.... I would suggest a progressive controller, which is not only safer but will also make it more driveable.
Something like a twisted sanity controller is perfect for the job, however the solenoids you use for the delivery need to be capable of being driven by a progressive system.
I've got most of a Wizards of Nos kit sat in my garage - can't decide whether to use it or not :( It's got the Minimax progressive controller, solenoids and 2 5Ib polished bottles - which I thought may look kinda funky in the up-and-coming-sooner-or-later-probably-later install.
What about insurance, no company will touch you with NOS or would you not tell them. Also dont think the bottles last very long?
Actually, if it's a professionally installed / checked system, insurers such as Greenlight and Adrian Flux are happy enough to insure it; i believe that more specialist insurers are starting to realise it's not the risk that it's been made out to be.
isnt it illegal to have it on the road ?
went to my local jap tuner garage and they quoted me 1400 for a fully fitted kit with a controller and an extra fuel pump to spray in fuel mix with the nos thatwas for 100 bhp extra and it only worked on full throttle no "go baby go" button thought it was a bit pricey as to buy the bits works out about 600 squid seems easy to fit in a weekend
dont tell INS CO as you can pull it out in a jiify
hi guys......NOS seems to be the only way other than a turbo to get any real power out of my n/a. has anybody on here got NOS or knows someone who has?? if it won't fry my engine it will be the next thing i will buy?? cheers :)
ha ha ha ha ha ha ha ha ha ha ha ha ha ha ah aha hhahahahahhhahahahahahah
HANG ON..................
ha ha ha ha ha ha ha ha ha ah aha hahahahahahaha hja aha ha ahah aha aha ha aha aha ahaaaa:D
HERE WE GO:p
I think the Nitrous refils are pricey. I remember hearing £50 for an 11 Ibs refil.
And I think continuous use .. I've heard 2-3 minutes bounded around. Of course, you wouldn't use the N2O all the time.
I think tho, the progressive controller makes the N20 more smoother on the pistons as delivery of N20 corresponds to RPM. Which I've also heard it makes the usage of N20 more economical.
That's extremely pricey. With an uprated fuel pump you shouldn't need a seperate pump for fuel, that should be governed by the solenoids fed from a T off the fuel line.
If you're giving it a 100bhp fixed hit in a fairly standard car then you'll probably lose traction, not to mention most of your engine internals.
Nitrous is just like any other power-enhancing mod for cars - it takes knowledge and proper tuning to do it properly. After all, would you just bolt a single kit to your Supra and hoon around without getting it properly tuned?
If anyone is serious about nitrous, then I can't recommend the Wizards of Nos board enough.
:edit: Re-fills depend on the power you're using - expect 10-15+ minutes of continuous use on a 50 shot with an 11Ib bottle. For 2-3 minutes you'd have to be putting in some serious amount of nitrous!
:edit 2: Dammit! All this nitrous talk has made me make up my mind to put it on the TT! You evil people! :D
:edit 3: Progressive controllers are to minimise the effects of a sudden hit of nitrous - if it helps, think of it a bit like impact loading (getting past my techie threshold here!) They also save your traction either off the line or whilst moving. Ideally you should go progressive on anything 50bhp or over.
