dannyspeed Posted March 16, 2006 Share Posted March 16, 2006 ive got 19+9 alloys on the front and the car been lowered by 30mm and every now and then the wheels rub the arches slightly mostly at slow speeds if i hit a slight bump turning a corner. the wheels are Racing Hart CX's with goodyear eagle 245/35 tyres on. Is this a common prob and what can i do to fix it. Im planning on taking the beast on a track this year and would like to get this sorted before hand. Link to comment Share on other sites More sharing options...
Ian W Posted March 16, 2006 Share Posted March 16, 2006 well, you should either change to a 245/30 or a 235/35 as your current setup actually makes the rolling radius larger than stock anyway. Link to comment Share on other sites More sharing options...
Nic Posted March 16, 2006 Share Posted March 16, 2006 30mm drop and 19" wheels is going to make for poor track handling, are you able to raise the ride height? Link to comment Share on other sites More sharing options...
dannyspeed Posted March 16, 2006 Author Share Posted March 16, 2006 Na iv just got adjustable damping is what i got a bad setup then for track use? Link to comment Share on other sites More sharing options...
Nic Posted March 16, 2006 Share Posted March 16, 2006 Na iv just got adjustable damping is what i got a bad setup then for track use? 30mm drop at the front is quite a lot, that plus the combination of the 19" wheels and incorrect tyre sidewall heights, will not have a good effect on the handling. Link to comment Share on other sites More sharing options...
dannyspeed Posted March 16, 2006 Author Share Posted March 16, 2006 so is a 245/30 tyre better to go for then. il need to change them soon in any case. Link to comment Share on other sites More sharing options...
Nic Posted March 16, 2006 Share Posted March 16, 2006 so is a 245/30 tyre better to go for then. il need to change them soon in any case. It'll be the correct rolling radius then, which may solve the issue of the rubbing and make your speedo more accurate. Reducing the sidewall height though is only going to make the ride more harsh in combination with the 19's and low suspension. Link to comment Share on other sites More sharing options...
jazz1 Posted March 16, 2006 Share Posted March 16, 2006 buy coilovers then you can have it as low as you want and it wont touch a bit:D Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 16, 2006 Share Posted March 16, 2006 Na iv just got adjustable damping is what i got a bad setup then for track use? About as bad as it gets... Smaller rims, higher ride height. Too low, inappropriate rim size, sorry, it's just the way it is. Link to comment Share on other sites More sharing options...
Homer Posted March 16, 2006 Share Posted March 16, 2006 buy coilovers then you can have it as low as you want and it wont touch a bit:D What absolute rubbish. Also, the Supra has 'coilovers' as standard. Please stay out of the technical section until you have a clue what you're talking about Link to comment Share on other sites More sharing options...
