Can I add a short video ?
Nash
 Share
20 minutes ago, Mike2JZ said:
Auxillery Tensioner most likely. Had a few squeak like that when they are knackered whilst idling. If you look closely, you can see it jumping around, shouldnt do that
Thanks for that, is that the one top right in the video ?
That clicking is typically from the auxillery tensioner itself rather than the bearing. But if you take aux belt off and spin the wheel by hand you can determine if bearing is bad. Normally if the bearing is bad then you will feel a lot of side to side movement on it.
  • 4 weeks later...
9 hours ago, AC93 said:
Bloody heck, hopefully not much damage?!
On starting I saw smoke across the headlights, turned off engine and on opening bonnet the alternator then started burning with flames so ran in house and got bowl of water to put out, new one on order from Halfords for £168, Lucas 100 amp
 Share
