2jz vvti solenoid and complete housing wanted
edviss
 Share
  • edviss changed the title to 2jz vvti solenoid and complete housing wanted
Just now, Frank Bullitt said:
I think I still have my old one in a box in the loft if you want it?
Did you know they changed the design?
as far as i know they are all exactly the same. 1jz,2jz ge and gte 🙂 if you could have a look it would be perfect.
  • Like 1
Ooft w@nkers! I’m fairly certain I still have my old valve so you are more than welcome to that if I have it. I may have a new filter too, just not sure where.
There was nothing wrong with it, I just swapped it out as it had been redesigned at some point.
I can’t help you with the cast piece unfortunately but a decent foundry up north might be able to fix it if you have no joy in sourcing a replacement.
i do have a filter, it did clean up pretty well. if you could have a look for a solenoid that would be perfect 🙂 i was thinking the same.. getting housing welded if i wont find anything clean up for sale.
Okay, i’ll have a look tonight. I have used these guys for past projects when I needed cast iron welding done -  https://www.castironwelding.co.uk they might be able to help you with that piece even though it is ali.
  • Like 1
 Share
