2jz gte vvti mr2 project 6 speed manual.
Shane34
 Share
Looking for some advise between link or syvecs for the ecu on this mr2 project. Full custom wiring to be done so no pluging options
Set up will be single g35 1050, 1200cc injectors. Head work, cams etc.
Currently unsure if ill be going forged at this stage but may end up for future proofing the set up.  Potential possibility of a flex fuel system with a 2nd row of injectors.
Ill probably end up with needing traction control, got no abs so some sort of wheel sensors will be required.
Maybe wheelie or front lift sensors if i go more towards the drag set up.
Will require the normal saftey sensors as you would expect.
Aim of the car will be a bit of everything, track, drag, street.
Whats your thoughts will be mapped at SRD.
 Share
