UK-Spec Stock ECU Running Single Turbo
Big Supes
Howdy peeps, just wondering what people's thoughts are on this? As the UK cars run a MAF sensor, you should be able to run a single turbo providing boost is limited to the stock fuel system?
I'm looking to go single, but I had planned to go manual first... but recently the twins are showing signs of wear so I'm thinking about getting a single kit fitted and then an ecu and fuel system later down the line.
There was a white Auto a while back that was running a single on a stock ECU, not sure what it was like to drive though. I think @keron bought/sold it but it was a quite a while ago!
1 hour ago, blythmrk said:
Yes I think you can!
I think Burma ran a stock U.K. ecu with a single setup originally?
I believe Burner did. I'm not sure if he was running too much boost or boost spiking, but I recall him telling me it ran a bit lean.
