APRIL update: Random Supra bits
AC93
 Share
Hi all,
So now my Supra is running and these bits are surplus :) Plenty plenty more will be for sale including GE non VVTi engine and W58 gearbox kit, plus all ancillaries from GE VVTi engine - just need to sort it through and get pics but for now:
Brand new - TPS, Bosch knock sensors and Bosch MAP sensor, AN10 drain pipe and fitting were fitted but never used
Diff - A01A - £150
MAP sensor - £25
Fuel pump ECU - £50
AN10 Extended drain fitting and drain line (straight on turbo end, 45 degree on sump end) with Aerospace heat sleeve - £30
AN10 standard fitting flange (perfect for na-t sumps) £10, packaging opened but never fitted!
Grey cat temp sensor (I think) - £10
Diff shell (200mm) - £50 or £80 with the missing bits (ring/axle joints etc. sold as spares)
Coolant res bottle - £15
GE exhaust manifold/downpipe - £50
HKS mushroom filter - £15
GE VVTi inlet manifold - £20
Charcoal canister - £20
OEM Knock sensors - £20 (both)
GE igniter - £40
No idea if these prices are ridiculous or reasonable, open to offers :)
Collection from Luton / St. Albans / Milton Keynes :)
Edited by AC93
Update (see edit history)
Also for sale:
Ford 2 Pin Idle Control valve, ideal for saving outputs on your ECU
Brand new, never used. 5 year warranty - £40 SOLD
3" black intercooler pipe kit:
Cost me £120, open to offers
2x straights
2x 45 degrees
2 x 180 degree bends, bag of clamps and joiners
Edited by AC93
ICV sold (see edit history)
More parts:
ECU is Supra GE manual £200
Other ECU is GS300 in engine bay case £35
Cams are GE VVTi £25
Engine harness is GS300 VVTi £30
Alternator £20
Everything else is £10 + postage, some bits are free as untested
  • AC93 changed the title to UPDATED: Random Supra/GE bits
  • 2 weeks later...
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
  • AC93 changed the title to APRIL update: Random Supra bits
  • 1 month later...
 Share
