Engine bay question
mike33
 Share
Hi guys some of you have had the chrome boxes fitted covering the brake master cylinder and the abs unit!
Did you have to lower the brake master cylinder abit and if you did is it easy to lower!
I have seen some on Facebook and not sure to go with them! Is there anywhere else that do them I looked on garage whitzbiz but couldn't find any!
Cheers guys in advance!
Hi Mike,
I know you do need to make some adjustments when you fit the engine bay covers, but not done mine yet.
I was pointed in the direction of Gary England from here/Facebook. He does a carbon set that looks stunning, but last I heard the mould needs re-doing before he can offer any more sets.
Hope this helps a bit until someone with these can chime in with more info on the fitting side of things. :)
I have a set of the Gary England carbon ones on mine. The panels themselves needed some modding as they were designed to work with a single turbo set-up. I also had to remove the carbon canister to get them to fit. I didn't have to move anything else.
I think they look great though :)
Edited by ben_harmer32 (see edit history)
Cheers guys I have spoke to Gary! Do SRD make them too? But polished not sure which I may go for!
Don’t believe Lee P/SRD so offer these anymore mate, I asked Lee first off and he pointed me in the direction of Gary England for a set. Think they had a set knocking around, but James used those on his car. :)
 Share
