bayside_supra Posted August 8, 2018 Share Posted August 8, 2018 (edited) Hi guys Haven’t put the roof on my car in months and this has started becoming quite irritating. Has anyone got a fix for it? No doubt you aerotop owners will know what I mean. Roof rattles in the boot as you drive along, never used to do it! http:// Edited August 8, 2018 by bayside_supra (see edit history) Quote Link to comment Share on other sites More sharing options...
evinX Posted August 8, 2018 Share Posted August 8, 2018 Mine dosent make a noise, the bottom latches, the outer bolt casing kinda pushes into them and gives a tight fit, you flaps arnt down are they? Quote Link to comment Share on other sites More sharing options...
ben_harmer32 Posted August 9, 2018 Share Posted August 9, 2018 Mine only ever made a noise when i didn't put it in the boot properly. Need to make sure the back engages properly before clipping in the front. Quote Link to comment Share on other sites More sharing options...
norman1979 Posted August 9, 2018 Share Posted August 9, 2018 Atleast you can get it in the boot. I have had mine 6 months and not worked out how to stick it in there despite reading quite a few posts about it Quote Link to comment Share on other sites More sharing options...
Ric Posted August 9, 2018 Share Posted August 9, 2018 Atleast you can get it in the boot. I have had mine 6 months and not worked out how to stick it in there despite reading quite a few posts about it one side down first, then feed it inwards, it's a bit tricky. Quote Link to comment Share on other sites More sharing options...
evinX Posted August 9, 2018 Share Posted August 9, 2018 Atleast you can get it in the boot. I have had mine 6 months and not worked out how to stick it in there despite reading quite a few posts about it one side down first, then feed it inwards, it's a bit tricky. Boot instructions label Quote Link to comment Share on other sites More sharing options...
bayside_supra Posted August 10, 2018 Author Share Posted August 10, 2018 Mine dosent make a noise, the bottom latches, the outer bolt casing kinda pushes into them and gives a tight fit, you flaps arnt down are they? It’s all fitted properly, it’s just not possible to get it fittings tightly anymore. Almost like some rubber or something has worn out... anyone else experienced this? Quote Link to comment Share on other sites More sharing options...
tintinmt Posted August 11, 2018 Share Posted August 11, 2018 You've probably considered this, but could it be the rear hatch making the noise as opposed to the roof. i.e does it only make the noise with the roof in the boot? I've never had noise from the roof but plenty from the hatch. Quote Link to comment Share on other sites More sharing options...
bayside_supra Posted August 13, 2018 Author Share Posted August 13, 2018 You've probably considered this, but could it be the rear hatch making the noise as opposed to the roof. i.e does it only make the noise with the roof in the boot? I've never had noise from the roof but plenty from the hatch. Definitely the roof bud. No noise when it’s not there and the noise I’m complaining about is the one you can see in the video. The roof is just not that tight on the front clamps anymore. Anyone got any other suggestions? Quote Link to comment Share on other sites More sharing options...
charlton Posted August 13, 2018 Share Posted August 13, 2018 Mine only ever made a noise when i didn't put it in the boot properly Same here for me Quote Link to comment Share on other sites More sharing options...
