Disc upgrade
sidewaysdan
^ As this man says, OEM. The source of the metal used in grooved discs is supposed to be some what on the cheap side.
I believe CW does pads if you wanted something to aid stopping power and if you don’t already have them fitted Goodridge braided lines and a decent fluid will also help.
You could also look into a Brake Master Cylinder Stopper.
