puggy Posted July 20, 2017 Share Posted July 20, 2017 Hi guys, I'm after some help/diagnosis!! Recently there has been an intermittent squealing noise coming from what I believe, is the front of the car! The symptoms are as follows: - Whilst driving, every now and again, a squealing noise appears which at times can be loud. With the windows down, it seems to come from the front left and right. - It appears worse when steering - Can drive for several miles without any noise so it is completely random. - No noise during startup or when car is stationary and running idle. I have checked steering fluid and it is fine. I'm not very technical so in terms of belts etc, I have no idea what to look for! Any ideas? Cheers. Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 20, 2017 Share Posted July 20, 2017 Possibly the crank damper has de-laminated and is slipping, do the Tipex test on it. Some makes of auxiliary belt make random squeaks and squeals, especially on alloy pulleys. PAS pump bearings can squeal, so can the bearings in the auxiliary belt tensioner pulley. Link to comment Share on other sites More sharing options...
Dnk Posted July 20, 2017 Share Posted July 20, 2017 Heres the crank pulley showing the lines moved meaning the rubber part is separating from the steel part Link to comment Share on other sites More sharing options...
Scooter Posted July 20, 2017 Share Posted July 20, 2017 (edited) This can cause a lot of damage if it lets go at high rpm so check it all sooner rather than later. http://www.mkivsupra.net/vbb/showthread.php?238433-Crank-Pulley-de-lamination&highlight=crank+pulley Edited July 20, 2017 by Scooter (see edit history) Link to comment Share on other sites More sharing options...
puggy Posted July 20, 2017 Author Share Posted July 20, 2017 Thanks for the advice. I have put tipex on so next time I drive the car I'll check it. Just checked steering fluid again when engine is hot and it is below where the marker is. Could it be that it needs topped up which is where the noise is coming from? Link to comment Share on other sites More sharing options...
mrboomberang Posted July 20, 2017 Share Posted July 20, 2017 I had a lot of strange noises coming from my steering after a full flush with the advice on here the noise disappeared I thought the rack was knackered it was that bad Link to comment Share on other sites More sharing options...
puggy Posted July 20, 2017 Author Share Posted July 20, 2017 Ok so drove the car until noise appeared. Checked tipex and it all still lines up. I'll top up the steering fluid and see if that sorts it. Link to comment Share on other sites More sharing options...
Scooter Posted July 20, 2017 Share Posted July 20, 2017 If the steering fluid needs a fair amount you may have a leak (as it shouldn't get 'used' as such), the front cooler (look in the front bumper at what looks like a kettles heating element, or in the passenger side front air duct for signs of fluid. Or it could be leaking into the steering rack gaitors so check them too, hope it's not this as it's the more costly issue. Link to comment Share on other sites More sharing options...
Boyne Posted July 20, 2017 Share Posted July 20, 2017 I had similar prob after ps fluid change but was more a high pitch Chrip then squeal. Link to comment Share on other sites More sharing options...
rider Posted July 20, 2017 Share Posted July 20, 2017 I had a crank pulley break up but if you are sure that's not the issue I had a squeal on my Mk3 with a dry viscous coupling on the cooling fan. Ran some oil into the fan and the squeal went. Not sure if the Mk4 has the same viscous drive as the mk3? Link to comment Share on other sites More sharing options...
Dnk Posted July 20, 2017 Share Posted July 20, 2017 (edited) Does it do it when you turn the steering lock to lock when stationary with the engine running ? Edited July 20, 2017 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
puggy Posted July 20, 2017 Author Share Posted July 20, 2017 I had similar prob after ps fluid change but was more a high pitch Chrip then squeal. It is like a chirping noise, on and off. Link to comment Share on other sites More sharing options...
puggy Posted July 20, 2017 Author Share Posted July 20, 2017 Not really lock to lock, mainly half turn. Generally no noise when driving in a straight line. No noises whatsoever when stationary. I do think that I have a minor leak, I thought it was maybe oil as I have noticed a few drops every now and again on the driveway but it is probably the power steering fluid. I'll top it up with 10k Boost Stop Leak and see if that changes things. I'll update the thread in a few days with how I get on. Link to comment Share on other sites More sharing options...
Boyne Posted July 20, 2017 Share Posted July 20, 2017 Not really lock to lock, mainly half turn. Generally no noise when driving in a straight line. No noises whatsoever when stationary. I do think that I have a minor leak, I thought it was maybe oil as I have noticed a few drops every now and again on the driveway but it is probably the power steering fluid. I'll top it up with 10k Boost Stop Leak and see if that changes things. I'll update the thread in a few days with how I get on. Sounds like same noise I had mate. Link to comment Share on other sites More sharing options...
puggy Posted July 21, 2017 Author Share Posted July 21, 2017 Well it turns out I'm an idiot! Noise is a chirping noise that in on/off coming from the front near side wheel. Noise goes under braking! Possible wheel bearing issue? Link to comment Share on other sites More sharing options...
Dnk Posted July 21, 2017 Share Posted July 21, 2017 Well it turns out I'm an idiot! Noise is a chirping noise that in on/off coming from the front near side wheel. Noise goes under braking! Possible wheel bearing issue? Or the caliper is seizing Link to comment Share on other sites More sharing options...
puggy Posted July 21, 2017 Author Share Posted July 21, 2017 Yeah I thought that too, the rear calipers seized last year not long after getting the car. Link to comment Share on other sites More sharing options...
Dnk Posted July 21, 2017 Share Posted July 21, 2017 Yeah I thought that too, the rear calipers seized last year not long after getting the car. Does your car have the sliding carrier type, 2 pistons I'd get them refurbed even if that's not the problem unless they have been done of course They're prone to the carrier pins seizing as well as the pistons Link to comment Share on other sites More sharing options...
Boyne Posted July 21, 2017 Share Posted July 21, 2017 Well it turns out I'm an idiot! Noise is a chirping noise that in on/off coming from the front near side wheel. Noise goes under braking! Possible wheel bearing issue? Noises can drive ya mad glad you found the problem Link to comment Share on other sites More sharing options...
Dave Posted July 21, 2017 Share Posted July 21, 2017 If the steering fluid needs a fair amount you may have a leak (as it shouldn't get 'used' as such), the front cooler (look in the front bumper at what looks like a kettles heating element, or in the passenger side front air duct for signs of fluid. Or it could be leaking into the steering rack gaitors so check them too, hope it's not this as it's the more costly issue. mine was doing this. it was this pipe where its held onto the body by a bracket. replaced the leaking pipe and all is fine now its behind the front air scoop/mesh Link to comment Share on other sites More sharing options...
puggy Posted July 21, 2017 Author Share Posted July 21, 2017 Get the brakes checked on Tuesday so I'll get a diagnosis then. Link to comment Share on other sites More sharing options...
