K22SUP Posted June 21, 2017 Share Posted June 21, 2017 Hi guys I have noticed the box slipping between gears and when am really hard on the throttle now and then is this likely to be a torque converter or box is there any way to tell which one I did have a clicking noise under light throttle also have started getting shudder when lifting off lightly and donut and centre bearing brand new what's your thoughts guys also is non turbo box the same as turbo or what other torq converter fits if any as it's discontinued cheers Link to comment Share on other sites More sharing options...
Iky Posted June 21, 2017 Share Posted June 21, 2017 Hi guys I have noticed the box slipping between gears and when am really hard on the throttle now and then is this likely to be a torque converter or box is there any way to tell which one I did have a clicking noise under light throttle also have started getting shudder when lifting off lightly and donut and centre bearing brand new what's your thoughts guys also is non turbo box the same as turbo or what other torq converter fits if any as it's discontinued cheers Boxes are different. Torque converters are different sizes. Have a look at the Hybrid Auto Gearbox Group DavidP has set up in the communities menu. Link to comment Share on other sites More sharing options...
K22SUP Posted June 21, 2017 Author Share Posted June 21, 2017 Thanks all have a look Link to comment Share on other sites More sharing options...
Frank Bullitt Posted June 21, 2017 Share Posted June 21, 2017 Incase you have trouble finding it - http://www.mkivsupra.net/vbb/group.php?groupid=57 Link to comment Share on other sites More sharing options...
K22SUP Posted June 21, 2017 Author Share Posted June 21, 2017 Thanks I was frank Link to comment Share on other sites More sharing options...
Sheefa Posted June 21, 2017 Share Posted June 21, 2017 Can you use some punctuation to break up the long paragraph mate it makes my eyes hurt. Whifbitz sell a torque converter. Not cheap mind.... http://www.garagewhifbitz.co.uk/titan-motorsports-2490.html Link to comment Share on other sites More sharing options...
mellonman Posted June 21, 2017 Share Posted June 21, 2017 Thats the box dead mate, had the same when mine went Link to comment Share on other sites More sharing options...
K22SUP Posted June 21, 2017 Author Share Posted June 21, 2017 Thats the box dead mate, had the same when mine went That's no good mate what was your symptoms did you try change torque converter Link to comment Share on other sites More sharing options...
Swampy442 Posted June 21, 2017 Share Posted June 21, 2017 First off, fluid level and condition, flush the box with fresh fluid and see how it goes. When was it last serviced? Link to comment Share on other sites More sharing options...
K22SUP Posted June 21, 2017 Author Share Posted June 21, 2017 Serviced not long ago but I didn't change filter pan I took it out tonight and warned it up took it a blast and never slipped at all weird an wondering if it's temp related as yesterday was really hot but there doesn't seem a way to tell if it's box or converter fluid looks nice red and no burnt Smell same when it was changed Link to comment Share on other sites More sharing options...
mellonman Posted June 22, 2017 Share Posted June 22, 2017 That's no good mate what was your symptoms did you try change torque converter Symptoms Slipping in high gears when on boost . When driving around town the box was making a ticking noise from outside the car that increased with revs. Changed the box kept my tc as I have a modified tc now all.sweet Link to comment Share on other sites More sharing options...
K22SUP Posted June 22, 2017 Author Share Posted June 22, 2017 Do you think the modified torque converter made a difference and when u say modified is it high stall Link to comment Share on other sites More sharing options...
mellonman Posted June 23, 2017 Share Posted June 23, 2017 I was trying something out in the UK as the import and delivery of tc are rediculous it's about the same price as the tc it's self iirc a tc was 550 then 350 import and delivery. The modifications only raised the flash point about 600 rpm so not really worth it . I think a 3200 stall would be the best bet for a street single . Link to comment Share on other sites More sharing options...
and1c Posted June 24, 2017 Share Posted June 24, 2017 Did you check the fluid level? Best bet would be to get the box rebuilt and uprated, I saw a link on here to a UK guy that was very good and did one for about £800.. WIll try and find it if you need it. Link to comment Share on other sites More sharing options...
Dave Posted June 24, 2017 Share Posted June 24, 2017 Did you check the fluid level? Best bet would be to get the box rebuilt and uprated, I saw a link on here to a UK guy that was very good and did one for about £800.. WIll try and find it if you need it. Wouldn't mind that link. Link to comment Share on other sites More sharing options...
andz222 Posted June 25, 2017 Share Posted June 25, 2017 Link to comment Share on other sites More sharing options...
