Guest Butane_Dan Posted July 5, 2016 Share Posted July 5, 2016 Hi guys, what's the best engine oil to use in a 95' n/a supra? (UK) I've noticed on a next day start up that the oil light stays on for a couple of seconds and the engine sounds rough for that period before the oil must circulate and the light goes out. Is this a because of a cheap oil grade? Or maybe in need of a change? I only acquired the car a few weeks. Appreciate any input. Thanks Link to comment Share on other sites More sharing options...
Parm_93 Posted July 5, 2016 Share Posted July 5, 2016 Take a look at this thread mate http://www.mkivsupra.net/vbb/showthread.php?56684-FAQ-Oil-Fluid-Interval-Capacity-Steering-Brake-Coolant-Diff-Engine Link to comment Share on other sites More sharing options...
Guest Butane_Dan Posted July 5, 2016 Share Posted July 5, 2016 Take a look at this thread mate http://www.mkivsupra.net/vbb/showthread.php?56684-FAQ-Oil-Fluid-Interval-Capacity-Steering-Brake-Coolant-Diff-Engine That is like given access to holy scriptures!! Thanks for that - - - Updated - - - Still don't know what's in mine and if to top up on a guess or get an oil change!? Link to comment Share on other sites More sharing options...
Scooter Posted July 5, 2016 Share Posted July 5, 2016 What oil filter is on it? Is it really a whole couple of seconds? Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted July 5, 2016 Share Posted July 5, 2016 Oil wise the choice is yours really, pretty much all modern oils exceed the spec of the original, so it will fine, one thing to avoid is going too thick, as this will over work the oil pressure relief valve and make the pump work harder, and if the pump is work it will cause more leakage to the FMS, i always used a 10W40 semi synth. Not sure about the rough sound, but the delay in making oil pressure could be just the oil grade, or a bad or partially blocked filter. Link to comment Share on other sites More sharing options...
Dnk Posted July 5, 2016 Share Posted July 5, 2016 I'd be doing an oil & filter change, what mileage has your car done, does it have any service history Link to comment Share on other sites More sharing options...
Guest Butane_Dan Posted July 5, 2016 Share Posted July 5, 2016 I'd be doing an oil & filter change, what mileage has your car done, does it have any service history Guys thanks for all you advise. She's done 107,000 km. Unfortunately the sell was the widow and although there is some service history her husband done much of the work himself. So there is no way of knowing Link to comment Share on other sites More sharing options...
Guest Butane_Dan Posted July 5, 2016 Share Posted July 5, 2016 I think I will do an oil change to be safe. And use a semi 10-40 as advised. She seems to run well and been looked after. I paid £2,950 fodr her so there us still some left in the pot to do some basic matainence. Link to comment Share on other sites More sharing options...
Mike2JZ Posted July 5, 2016 Share Posted July 5, 2016 Always worth doing a fluid + filter changes on the car just to put your mind at ease knowing it's been done. I would look at the coolant level as well Link to comment Share on other sites More sharing options...
Annabella Posted July 5, 2016 Share Posted July 5, 2016 Yep do all, air, oil, and coolant as stated, doesn't cost much from a good local motorfactor and its remarkably easy to do, even I did it. Link to comment Share on other sites More sharing options...
Guest Butane_Dan Posted July 5, 2016 Share Posted July 5, 2016 Great advise guys Link to comment Share on other sites More sharing options...
