engine warning lights
kevin smith
Hi guys my Jap import had a problem with the engine warning lights coming on when i booted it, and when it hit 80mph and the gearbox would get confused and the OD light would flash on and off. I got advice from you, to change the KPH to MPH converter, i have done this and the gearbox is changing gear very nicely now and the OD light has stopped flashing. But when i booted it the engine warning lights came on again, any ideas or help would be very much appreciated.
Thanks Kevin.
Thanks rip, the brake fluid is fine. It's the main warning light/ handbrake light and the little engine shape light on the right hand side top of the dash above the clock cluster.
Ps i have no way of checking error codes.
you can check the error codes at home by bridging the diag ports with a paper clip then count the number of flashes on the dash. Search for paper clip test and go from there :)
