mattdavies Posted June 24, 2016 Share Posted June 24, 2016 I am having problems with the car not staying / changing down to first gear on the autobox. When normal driving in 'D' it is fine and if i hit kick down it will stay in gear. but if i try it in manual mode with 95% throttle it changes up at 3500rpm roughly. Any ideas what this may be ? Link to comment Share on other sites More sharing options...
tkddav3 Posted June 24, 2016 Share Posted June 24, 2016 Buy a manual... Link to comment Share on other sites More sharing options...
Annabella Posted June 24, 2016 Share Posted June 24, 2016 Buy a manual... Pffft, I like my cruiser auto thanks Link to comment Share on other sites More sharing options...
mellonman Posted June 24, 2016 Share Posted June 24, 2016 Problems like that are often oil related level / condition Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 25, 2016 Share Posted June 25, 2016 I am having problems with the car not staying / changing down to first gear on the autobox. When normal driving in 'D' it is fine and if i hit kick down it will stay in gear. but if i try it in manual mode with 95% throttle it changes up at 3500rpm roughly. Any ideas what this may be ? Any codes stored? Link to comment Share on other sites More sharing options...
mattdavies Posted July 1, 2016 Author Share Posted July 1, 2016 Checked the codes today and Got a 14 & 25, think these may be from the coilpack clips, have resolved this issue now. Will double check the auto fluid Link to comment Share on other sites More sharing options...
mattdavies Posted September 20, 2016 Author Share Posted September 20, 2016 Still having issues with this. Fluid is good, is a good colour. I am now thinking it might be throttle related. Any one know how to reset the throttle position sensor ? Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 20, 2016 Share Posted September 20, 2016 Does it change up to 2nd at about 3500 RPM in Manual Mode if the traction control is turned off? Link to comment Share on other sites More sharing options...
mattdavies Posted September 20, 2016 Author Share Posted September 20, 2016 It changes up quite quickly couldn't tell you with out driving it again exactly when it changes and i can sometimes get it to stay in first gear when kicked down. Link to comment Share on other sites More sharing options...
andz222 Posted September 20, 2016 Share Posted September 20, 2016 are you running stock ecu or standalone unit Link to comment Share on other sites More sharing options...
mattdavies Posted September 20, 2016 Author Share Posted September 20, 2016 are you running stock ecu or standalone unit I am running a mines ECU, have been for a while Link to comment Share on other sites More sharing options...
andz222 Posted September 20, 2016 Share Posted September 20, 2016 ok Link to comment Share on other sites More sharing options...
and1c Posted September 20, 2016 Share Posted September 20, 2016 I am running a mines ECU, have been for a while are you still running the Auto ecu to control auto gearbox functions? Link to comment Share on other sites More sharing options...
mattdavies Posted September 20, 2016 Author Share Posted September 20, 2016 are you still running the Auto ecu to control auto gearbox functions? The Mines replaces the whole ECU and is made for an Auto Link to comment Share on other sites More sharing options...
