Uk spec caliper material ?
Iky
Cast aluminium and cast steel
Cheers Dunk!
Do you know if it is a black zinc plating all over on them from factory? I'm currently doing a refurb on mine and want to get the internal bores plated to stop them rusting again.
Surely you would be better off selling these and buying brand new calipers by the time you're done?
It's only the plating I can't do myself. I don't have a clue how much that costs yet.
So what process and material will the plating be, given half is cast iron, half cast aluminium alloy? Piston bore size reduction due to plating thickness? Seal groove reduction in width and depth? Have you considered all these things?
Of course..
Not! :D
Joking aside, The aim of this thread was to find out if this is something worth doing. From some research I have done it seems there are coatings which do not change the dimensions. Such as chemical blacking.
It might only be the iron side that needs doing.
If the info is correct- http://www.moss-metal-finishing.co.uk/processes/
And it would seem the factory calipers have some sort of black coating on them. Would It not be a good idea to replicate so they will last another 20 years?
I was also thinking, if they are being blasted/ stripped, would this not remove a layer of the metal anyway?
I have seen the inside of "refurbed" calipers that have started to rust on the top section of the bore. Back to square one in my opinion.
I usually like to do a job once and do it properly. But maybe I'm losing the plot, I've not even taken them off the car yet to inspect. :looney:
Edited by Iky (see edit history)
I re-liner master and slave cylinders quite regularly, using stainless steel sleeves, but the trouble with calipers is they need the seal groove in the bore, unless they are weird junk like early Corvette calipers with O ring seals on the pistons. (Only the Yanks could think of that, then, despite appalling reliability and poor performance, continue to use them for bloody years...). Boring most calipers out big enough to take a sleeve thick enough to hold an internal groove is a none starter, not enough meat! Plus, how many people know what's special, and vital, about the seal groove??
POS Corvette caliper:
Good info here. I will refurbish mine in the next weeks, but I'm still unsure on how I'm gonna repaint them.
Surely a good clean with a brush and some brake cleaner, and then carefully paint using a pencil brush will do the trick? What kind of paint should be used ?
Should this be done only when all seals and pistons are off or on the contrary leave those on to protect the seal grooves, etc.?
I'd recommend Foliatec caliper/engine lacquer, it's a 2K paint which you mix with a hardener. It's not the cheapest but brushes on very easily and sets to give a very smooth, hard wearing, bright finish. It comes in a small can but should be enough to do all the calipers, it starts to harden after around 20 minutes so only mix a quarter of the tin at a time so you can take your time doing each caliper. If you're refurbishing the calipers, mask and paint them before rebuilding them.
