Cooling/ Radiator issue
Acton
1993 j-spec na auto
I bought this car yesterday, and after my 200 mile trip home noticed that the front of the car was covered in brown gungy stuff that seems to have come from the radiator/ catch tank. I can't see any loose hoses or where it's come from. It was running pretty high on the temp gauge, roughly 3/4 to Hot.
I checked the oil cap and it's clean, so don't think it can be head gasket related. Any one able to help?? This isn't how I imagined my first venture into Supra ownership was going to go... :(
Pictures:
Edited by Acton (see edit history)
That is some pretty scummy rusty deposits! What does the stuff in your expansion tank (in front of the rad black plastic cap) look like?
The rad should always be full of coolant, how much does it take to brim it back up? What does the bottom of your rad cap look like?
It MIGHT just need a really good flush with a hose pipe, a new rad cap and some nice fresh coolant.
Head gasket failures are rare.
Start by flushing out the system, refill with fresh coolant, check all jubilee clips are tight and there are no leaks, clean up the surface where the radiator cap seals against and fit a new Toyota radiator cap.
I think a 200 mile trip wouldn't have been possible with a serious issue.
Ideally you'd remove both top and bottom rad hoses and flush that through.
Undo the matrix pipes at the back of the engine and flush this (careful to stop water going down the spark plug wells)
undo the very awkward to get to block drain (it's behind the rear most exhaust manifold) and then flush some more!
This will give you the most thorough flush
Thanks Scooter, and thank you for the offer of help. I may take you up on that if I have any problems (I'm in Frimley so not far at all!) I'm planning on flushing it at the weekend. And I'll have a look for standard rad caps too, just in case :)
No probs, I got a cap from ebay recently jap-hogs was the seller, well worth the tenner if the one you have looks old, the area of leaking suggests it's at least part to blame.
I just recently did my water pump and had all the relevant pipes off, so yeah if you get stuck drop me a message.
The coolant should be Glycol Ethylene based, colour is a manufacturers guide and not a specific type of coolant
I'd flush the system thoroughly and before refilling with coolant refill with water and pressure test it.
If you go onto the homepage at the top left you will find the Repair manuals which cover just about everything
on the mkiv, here is the Cooling system
http://www.mkivsupra.net/vbb/content.php?60-Cooling-System
Thank you for that :)
That looks like radweld to me. As above though, take the rad off and flush everything through, hosepipe in the top rad hose, maybe even flush the heater matrix out too
Good advice
I'd also be replacing the thermostat and rad cap for genuine Toyota parts too.
If its the cars original rad its probably scrap and well worth replacing it. Before you do though the system needs
a serious clean, rad weld is for the bodgit and scarper club
Easiest way is to just go to Toyota with your vin and they can sort you out with what you need
Luckily there's a Toyota dealership about 400m down the road. I'll pop in to their parts dept then
