Supra wiring loom points question..
MattP
I have recently changed the following earth points with stainless steel bolts
*Front right wing
*front left wing
*the one behind the battery
*the one at the top rear of the engine that attaches to the firewall
My car has since developed a misfire is this a possible culprit?
Are my stainless bolts poor conductors compared to the stock steel bolts?
I think stainless steel isn't as good a conductor as normal steel. I would swap the bolt back to stock and see if it makes a difference.
I take it you clean the metal underneath the earth, if you had good contact in the bolt I am sure the bolt material won't make too much difference.
Although S/S is not as good as a conductor as steel its not far off. Would not have thought this would cause you an earth problem.
I would check all earth connections again, if you have a meter check continuity at these connection points.
Most bolted ground points just use the bolt or stud as a calmping medium. The conductive path is normally betwen the wire eyelet tag and the sheet steel of the bodyshell or whatever. The clamping medium could be insulating nylon, if the eyelet and its ground point are clean metal. I VERY much doubt the stainless fasteners are directly the cause of your issues. VERY VERY much doubt it!
Il check the surfaces again and swap the 5 offending bolts for steel and report back gentlemen...
Cleaned the points and holes out with brake cleaner and swapped out the stainless for new steel bolts and washers today it did not rectify the problem...
Next I removed the plastic spark well cover and inspected the area in great detail no oil or contaminants in the wells or bad connections so all good.
which leads me to my final suspect the FCD I will report back shortly.
