supra_ufo Posted January 18, 2015 Share Posted January 18, 2015 [video=youtube;Xt4M6-M9jsg] I have a HKS welded into my intake pipe (not sure if that's the name) like the video above, you can see that there is a small hose coming out of the SSQ, Does this hose go into the pipe labelled 1 (in blue/purple) in the picture below? I will be removing the stock BOV and blocking the ends as marked on the diagram. What would be the consequences of blocking the purple 1 pipe and on the SSQ side not fitting a hose on there? thanks. Link to comment Share on other sites More sharing options...
Westy Posted January 18, 2015 Share Posted January 18, 2015 Link to comment Share on other sites More sharing options...
supra_ufo Posted January 18, 2015 Author Share Posted January 18, 2015 is that filter necessary Westy? Looks like I may need to buy a long hose then. thanks Link to comment Share on other sites More sharing options...
Ric Posted January 18, 2015 Share Posted January 18, 2015 Its a none return valve i think, rather than a filter Link to comment Share on other sites More sharing options...
np89 Posted January 18, 2015 Share Posted January 18, 2015 You know you can u7st run that hose to the pressure sourde on the inlet manifold. It doesnt have to run all the way across the engine like that! Link to comment Share on other sites More sharing options...
supra_ufo Posted January 18, 2015 Author Share Posted January 18, 2015 cheers lads. It did seem like a bit of a long run. Link to comment Share on other sites More sharing options...
