chilli Posted August 27, 2005 Share Posted August 27, 2005 Predicament: I have here a nice shiny new double de-cat pipe and restrictor waiting to go on my car I'd obviously like to get this fitted asap but I'm a tad low on spare funds. I'm wondering if I'm going to hit fuel cut with the extra boost and if I do what I could do about it. I could spend £70 on a vfcd as a temporary measure, but then that’s £70 wasted that could better be spent on an Emanage ultimate (which can also do fuel cut and is what I _really_ want). So here are my options: Leave it for now and wait until I have the spare cash for the Emanage Fit exhaust and risk it, drive carefully if it happens Fit exhaust, fit VFCD temporarily if required (£70 is more affordable) Fit exhaust, beg/borrow/steal money for a Emanage Ultimate You might well all say the last option, suppose I need to consider that my j-spec fuel pump might also be a weak link? Any opinions or ideas? Link to comment Share on other sites More sharing options...
Clarkey Posted August 27, 2005 Share Posted August 27, 2005 I'd go the 3rd option because you're going BPU .. then imo eManage would be overkill. If you're going to upgrade your turbo's, in the not-so-distant future, then sell your FCD then eManage it. And a Walbro Link to comment Share on other sites More sharing options...
supradibbs Posted August 27, 2005 Share Posted August 27, 2005 try and buy a second hand fcd then sell it once you can afford the emange thus costing you nothing in the short term Link to comment Share on other sites More sharing options...
chilli Posted August 27, 2005 Author Share Posted August 27, 2005 Ok thanks for the advice, I think I'm tending to agree with you now, it makes a lot of sense really. I was getting caught up in the bling of the emanage lol Think the plan is now: Get the exhaust fitted Fit a VFCD if required Fit UK spec brakes Fit a Walbro fuel pump and FPR Then think about the emanage, wideband etc think this is the best route, Wayne, when would you be available to fit the exhaust? I'm tempted to have a go on Monday myself but without a pit/ramp it's probably going to be a PITA lol Link to comment Share on other sites More sharing options...
carl0s Posted August 27, 2005 Share Posted August 27, 2005 don't forget you will defo need a restrictor ring since you've got a J-spec. Where is your double-decat pipe from? Is it an eBay one? Link to comment Share on other sites More sharing options...
Nic Posted August 27, 2005 Share Posted August 27, 2005 I was getting caught up in the bling of the emanage lol It's not bling it's power The EMU (or other similar fuel controller) is an important and VERY worth while mod on a BPU Supra IMO. I do agree though, that for the moment your best option would be to fit the FCD and fuel pump first and keep the boost levels sensible (1-1.1 bar). Once you can afford (including proper mapping and dyno time) sell the FCD and fit the EMU. On my own car (running stock blowers) the emanage was a very necessary mod, as I was running dangerously high EGT's at 1.2bar without it, so had tou keep to 1bar max. The emanage (original) made a very big difference to performance once fitted, going from around 370hp without at 1bar, to 430hp with at 1.2bar. Link to comment Share on other sites More sharing options...
chilli Posted August 28, 2005 Author Share Posted August 28, 2005 It's from Paul Wiffin, a two part 2.5" pipe with a suitable restrictor ring that should keep the boost below 1.2 bar - has the o2 sensor fitting for when I fit a wideband True it's not really bling, just perhaps not essential right now. I totally agree with you and my plan is to get the emanage on there at some point soon Sounds like I should get an EGT gauge fitted sooner than later then to keep checks on things? I look forward to the stage when it's all been mapped and dyno'd, just need to get there incrementally at the moment unless I find a spare money tree or get a pay rise lol thanks for all the help Link to comment Share on other sites More sharing options...
Nic Posted August 28, 2005 Share Posted August 28, 2005 I think you're right in the way you are doing it, the important thing is that if you are upping the boost then you can monitor what is going on ie, boost levels, exhaust temps, A/F etc.. The EGT and boost gauge will help and a dyno run to check fueling would be very worth while. Link to comment Share on other sites More sharing options...
RobSheffield Posted August 28, 2005 Share Posted August 28, 2005 It's not bling it's power The EMU is an important and VERY worth while mod on a BPU Supra IMO an Emu? how will that help? Link to comment Share on other sites More sharing options...
wkdtime Posted August 28, 2005 Share Posted August 28, 2005 lol haaaaaaaaaaaaaaaaaaaaaaaaaahahah got me in tears!! Link to comment Share on other sites More sharing options...
Nic Posted August 28, 2005 Share Posted August 28, 2005 an Emu? how will that help? see Greedy EMU HERE Link to comment Share on other sites More sharing options...
RobSheffield Posted August 28, 2005 Share Posted August 28, 2005 see Greedy EMU HERE hell, i still laughed - it was a BIT funny tho Nic, even you gotta admit!!! Link to comment Share on other sites More sharing options...
