jza800 Posted February 8, 2014 Share Posted February 8, 2014 (edited) First off all i haved tried the search button, but with no luck.. I have studied it for a long time and i have been looking in the forum, and there are 80% of all answers that they have 2 bar (28 - 32 psi) oil pressure on idle, where i have about 0,8 - 0,9 (13-15 psi) bar on idle .. what is normal oil pressure on the 2jzgte engine, i run 10w30 castrol oil on mine, and i see Cold startup idle : 70 psi cold hot : 8 - 10 psi (idle speed) wot : 60 psi (6500 rpm) what do you others see??? Edited June 30, 2014 by jza800 (see edit history) Link to comment Share on other sites More sharing options...
David P Posted February 8, 2014 Share Posted February 8, 2014 (edited) Without oil squirters, the GE engine has higher oil pressure at idle than GTE may be the answer. It'll be interesting to see how it works in the real world. Findings would be more meaningful with oil viscosity, idle rpm and engine miles. Edited February 20, 2014 by David P (see edit history) Link to comment Share on other sites More sharing options...
jza800 Posted February 8, 2014 Author Share Posted February 8, 2014 mine reads in km, and that is 120.000km for now Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted February 9, 2014 Share Posted February 9, 2014 I would suspect that if you where to run 10W40 which most do, you will see the oil pressure increase, from memory the std pressure is between 15 and 30PSI in the manual, I'll check tomorrow. Link to comment Share on other sites More sharing options...
jza800 Posted February 9, 2014 Author Share Posted February 9, 2014 106 views but only 2 replys, are there really so few that are running 2jzgte engines I would appreciate that you would find that out for me tricky ricky Link to comment Share on other sites More sharing options...
jay200bhp Posted February 9, 2014 Share Posted February 9, 2014 Three to four bar idle, eight bar on boost,I'm fully built block wise,have a boost logic pump and 264 cams, Link to comment Share on other sites More sharing options...
Guest Roger NE Posted February 9, 2014 Share Posted February 9, 2014 (edited) Surely the reason you're not getting many replies is because nobody has Oil Pressure Gauges ?! I have recently fitted a 2JZ-GE in my Mk3 Supra . . . and all Mk3s have Oil Pressure Gauges as standard (which I have connected to the 2J) My oil pressure on tickover (when at normal operating temp) is 40 psi . . . and at anything over 2000 rpm it's 65 psi. (with Castrol 10W-40 semi-Synthetic) Now I don't know much about the 2JZ engines, but I presume that the oil system is very similar to both the 7M engines . . . for example, the GTE also has oil squirters on the crankshaft . . . and we have often discussed Oil Pressure on the Mk3 Forum (as EVERYBODY has an oil pressure gauge) For a start, there is a pressure release valve after the Oil Pump, which opens at around 65 psi, so it should NEVER go above this figure. (would imagine the 2J has a similar system) The oil pressure on my 7M-GE was the same as I describe on my new 2JZ-GE. However, most people with 7M-GTE engines get much lower oil pressure . . . 5 - 10 psi on tickover, peaking 40 psi at higher revs. I put this down to the turbo engines typically being more worn, and having much more places to LOSE oil pressure as the engine wears, such as the turbocharger, and also having to feed the oil squirters . . . so they are unable to maintain the same oil pressure as the N/A version. However, I do remember driving a BRAND NEW turbo Mk3 when they came out, and seeing the same kind of oil pressures as I got on my N/A. So the pressures only seem to drop as the engines wear. By the way, the readings when COLD are not really relevant, as they will depend very much on the viscosity of the actual oil being used. Hope these observations are useful. Incidentally, I do think it crazy that Mk4 Supras DON'T have oil pressure gauges . . . I've never had a sports car without one - together with a temperature gauge they are essential to keep an eye on to make sure the engine is OK! Edited February 9, 2014 by Roger NE (see edit history) Link to comment Share on other sites More sharing options...
jza800 Posted February 9, 2014 Author Share Posted February 9, 2014 Roger ne very usefull answer, and a good description... but on question, tickover what do you mean with that?? Link to comment Share on other sites More sharing options...
Al Massey Posted February 9, 2014 Share Posted February 9, 2014 Roger ne very usefull answer, and a good description... but on question, tickover what do you mean with that?? Tick over is idle Link to comment Share on other sites More sharing options...
Guest Roger NE Posted February 9, 2014 Share Posted February 9, 2014 (edited) Tick over is idle Idle was always the American term ! But I notice a lot of English people seem to use it rather than tickover now ! (I suppose we'll all be saying Hood and Trunk before long!!) However, I do think it's crazy that the American still use our IMPERIAL terms, when many over here DON'T . . . Maybe it's my age, but I think that most Imperial terms are much easier to relate to than the Metric ones - psi, bhp, ft-lbs, etc etc Edited February 9, 2014 by Roger NE (see edit history) Link to comment Share on other sites More sharing options...
jza800 Posted February 9, 2014 Author Share Posted February 9, 2014 ok thanks for the explanation Link to comment Share on other sites More sharing options...
Al Massey Posted February 9, 2014 Share Posted February 9, 2014 Idle was always the American term ! But I notice a lot of English people seem to use it rather than tickover now ! (I suppose we'll all be saying Hood and Trunk before long!!) However, I do think it's crazy that the American still use our IMPERIAL terms, when many over here DON'T . . . Maybe it's my age, but I think that most Imperial terms are much easier to relate to than the Metric ones - psi, bhp, ft-lbs, etc etc Is that why they call them idle screws and not tickover screws? Link to comment Share on other sites More sharing options...
Guest Roger NE Posted February 9, 2014 Share Posted February 9, 2014 I seem to remember that the term Idle started to become more common in the 80s . . . Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted February 9, 2014 Share Posted February 9, 2014 106 views but only 2 replys, are there really so few that are running 2jzgte engines I would appreciate that you would find that out for me tricky ricky From manual, at idle 7.1 PSI or more GE-3,000 rpm GTE - 4,000rpm 47-84PSI Now the manual doesn't state a viscosity only API GLA rating, but the sticker on the the GTE engine states 10W30 but most use a 10W40 which will increases the oil pressure slightly, however on my GTE I have never seen less than 23PSI at hot idle and around 80-90psi at WOT, obviously you will be seeing well over 100psi on cold start up. One thing to bare in mind is that the GTE oil pump is very efficient, its quite capable of maintaining good oil pressure when its very warn, mine blew out the FMS due to a worn pump (search and you will find a lot about this) yet it was still maintaining the same pressure despite it being virtually scrap. The first symptom you will see if the pump is worn is the front main seal fail. Link to comment Share on other sites More sharing options...
jza800 Posted February 9, 2014 Author Share Posted February 9, 2014 on Cold startup mine is at 70-75 psi, and that is on bone Cold engine.. when i have warmed up, and the engine is on idle and with a oil temp at 90c it can go Down to 13 - 15 psi.. at full trottle/wot i never see more than 65 psi.. i dont have any front main seal problem.. Should i be worry about my numbers or is my numbers safe??? Link to comment Share on other sites More sharing options...
Al Massey Posted February 9, 2014 Share Posted February 9, 2014 on Cold startup mine is at 70-75 psi, and that is on bone Cold engine.. when i have warmed up, and the engine is on idle and with a oil temp at 90c it can go Down to 13 - 15 psi.. at full trottle/wot i never see more than 65 psi.. i dont have any front main seal problem.. Should i be worry about my numbers or is my numbers safe??? First off, where is your pressure sender unit? As that will have a huge impact on the reading Link to comment Share on other sites More sharing options...
jza800 Posted February 9, 2014 Author Share Posted February 9, 2014 in sandwitch plate between oil filter and engine.. Link to comment Share on other sites More sharing options...
Al Massey Posted February 9, 2014 Share Posted February 9, 2014 in sandwitch plate between oil filter and engine.. Ah right, you will be seeing different pressures then. Link to comment Share on other sites More sharing options...
jza800 Posted February 9, 2014 Author Share Posted February 9, 2014 many have the sensor there, to messure the pressure or oil temp.. but Again is my numbers safe or unsafe? i now that i am within the Toyota spec. but i am just a Little worried when so many have higere numbers then i have Link to comment Share on other sites More sharing options...
Guest Roger NE Posted February 9, 2014 Share Posted February 9, 2014 (edited) is my numbers safe or unsafe?Well according to Toyota you're safe, as you're obviously within their spec for the MINIMUM oil pressure . . . but that doesn't mean it wouldn't be better if it was higher ! Low oil pressure is very rarely due to a worn oil pump . . . it's down to wear in various engine components, effectively causing "leaks" in the system, which obviously reduce the pressure. (think of a hose pipe with lots of small holes along its length . . . it would be unable to maintain a high pressure) Not sure what difference it would make WHERE you sense the Oil Pressure - mine is sensed where the stock oil pressure switch normally screws into the block (using a Driftmotion adaptor line) So does the 2JZ not have an Oil Pressure Relief Valve, like the 7M ? Edited February 9, 2014 by Roger NE (see edit history) Link to comment Share on other sites More sharing options...
jza800 Posted February 9, 2014 Author Share Posted February 9, 2014 yes i does have a oil pressure relief valve.. can it be posible that the valve is stuck half open or full open.. can that be the reson off low oil pressure? Link to comment Share on other sites More sharing options...
Guest Roger NE Posted February 9, 2014 Share Posted February 9, 2014 (edited) Yes I've been doing some searching and found that they DO have a Pressure Relief Valve on the Oil Pump . . . but can't find the figure they're supposed to open at ! (as I say, it's around 65 psi on the 7M engines) As far as I'm aware they sometimes stick so that they don't OPEN when they should (causing excessively high oil pressure) . . . not heard of them sticking open. Coming back to the general issue . . . I've never bought a car for over 30 years that DIDN'T have an Oil Pressure Gauge . . . the hot oil pressure readings would be one of the first things I would check before buying a secondhand car, as it generally gave you an indication of the state of wear of the engine. Edited February 9, 2014 by Roger NE (see edit history) Link to comment Share on other sites More sharing options...
jza800 Posted February 9, 2014 Author Share Posted February 9, 2014 ok, i hope that there would be others inhere , there can put some light on this question, as this is for mkiv owners so there should be a good chance that there are some guyes that can come with a answer, about my pressure readings is safe or not I doubt that i am the only one with a oil pressure gauge in the car.. but thanks for you answer roger ne, it help me a Little further.. Link to comment Share on other sites More sharing options...
Al Massey Posted February 9, 2014 Share Posted February 9, 2014 many have the sensor there, to messure the pressure or oil temp.. but Again is my numbers safe or unsafe? i now that i am within the Toyota spec. but i am just a Little worried when so many have higere numbers then i have Yes many may have the sensor there, but the pressure is very different due to the sandwich plate. Link to comment Share on other sites More sharing options...
jza800 Posted February 10, 2014 Author Share Posted February 10, 2014 ok. but do you have lower or higere oil pressure at the sandwitch plate??? Link to comment Share on other sites More sharing options...
