wheel fitment
JK90
going to buy some new wheels for the car and wanting to know if this fitment will work or if I will have problems.
Front: 18x9.5, 5x114, et 38 (with 3mm shim making et35) or et30 with 245/40/18 tyres
Rear: 18x10, 5x114, et 35 with 265/35/18 or 275/35/18 tyres
will the front and rear arches need to be rolled? what geometry, what camber to run?
The rears should fit flush with the arches, you'll probably not need to roll the arches but it'll be close.
I wouldn't use spacers on the front, 9.5 +38 wheels will sit 3mm further out compared to the rears and the arches may need rolling, if you put spacers on they'd definitely need the arches rolling.
Quick questions : how many mm can you add through arch rolling?
Depends on what you are after and the car
Rolling will move the lip under the arch so that's a few mm there
Also when rolling a slight flare can take place, some more mm.
But if doing a good flare, where it is visible will give even more mm clearance.
So possibly 10-15 mm
Roger that. Thanks for the explanation.;)
Will I have any problems on the fronts?
Based on the widths and offsets the fronts will fit but the arches will need rolling a little so the tyres don't rub, you don't need the spacers.
Which brakes do you have fitted? http://www.mkivsupra.net/vbb/showthread.php?249089-Supra-Brake-setups&highlight=Brakes
if you have the larger 4pot front calipers you'll need to make sure the wheels clear them, post up pics of the wheels if not sure.
will that offset have the fronts flush with the arches?
Yes the front and rears will be flush with the arches, the fronts will be a few mm closer to the arches compared to the rears which is why the front arches will definitely need rolling so the tyres don't rub. The rears will be close so may also need rolling.
