Spark plug help please.
Suprakeith
Hi i changed my spark plugs today on na jspec supra and she not running right are denso 20s the same as ngk BKR7EIX-11 as the densos were in car and fitted the ngks today. Did replace dizzy and arm aswell but have put old ones back on with no luck. Going to put old plugs bk in tomoz morning. Does sound like car is missing
Yes all ht leads are on right numbers on dizzy and did push all ht leads in. Am going to have another go sunday. At minute am running old dizzy with old rotor arm and new plugs and sounds the same as when had new dizzy and arm fitted, so do belive it possibly the spark plugs or something else but did check all vaccum hoses and connections and they all fine
What do you mean when you say not running right ?
If you have a missfire you can narrow it down by removing a ht lead 1 at a time off the dizzy cap
which will show you which cylinder has a problem
NA's have BKR5EIX
IK20'S are the equivalent to BKR6EIX which you fit in a stock tt.
7's go in tt's running 1 to 1.3 bar
She sounds like she missing and have smell of fuel so dont think one or more plugs arent firing, and will try that one lead off at time idea see what cylinders arent firing. And i had the denso 20s in but i have a non turbo supra so could the new plugs be the wrong type then? The spark plug code is in 1st post
I think the same adam now been thinking about it, i got the plugs off ebay listed as na spark plugs which is lesson learnt for me. Will re fit the denso plugs and order some proper na sparks plugs next week, just a pain in the bum shall we say
