SupraStar 3000 Posted April 26, 2013 Share Posted April 26, 2013 Can anyone shed some light on this please. I can't quite understand the link below: http://mkiv.com/techarticles/airbag_light/airbag.htm Does it mean alternate the plugs in the diagnostic box (ie pulling them in and out) or does it mean run a wire to the negative battery and alternate which wire running from AB & TC socket i touch to the negative batter terminal. I'm confused Link to comment Share on other sites More sharing options...
tDR Posted April 26, 2013 Share Posted April 26, 2013 Can anyone shed some light on this please. I can't quite understand the link below: http://mkiv.com/techarticles/airbag_light/airbag.htm Does it mean alternate the plugs in the diagnostic box (ie pulling them in and out) or does it mean run a wire to the negative battery and alternate which wire running from AB & TC socket i touch to the negative batter terminal. I'm confused The latter - tappy tap tap Link to comment Share on other sites More sharing options...
RobUK Posted April 26, 2013 Share Posted April 26, 2013 plug a wire into AB and another wire into TC then alternate touching the wires in AB/TC onto the negative terminal - helps to have someone to look at the dash while you do it.... Good Luck Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted April 26, 2013 Author Share Posted April 26, 2013 Thank you both. Makes perfect sense now. Will give it a go tomorrow. Funny as this never happened on my NA, and i had the dash apart on that thing times. Link to comment Share on other sites More sharing options...
Thorin Posted April 27, 2013 Share Posted April 27, 2013 It's easy... Step 1. Open the boot. Step 2.... Link to comment Share on other sites More sharing options...
Josh42 Posted April 27, 2013 Share Posted April 27, 2013 Could you not just take the battery off for an hour to reset the ecu? Link to comment Share on other sites More sharing options...
RobUK Posted April 27, 2013 Share Posted April 27, 2013 Could you not just take the battery off for an hour to reset the ecu? Nope - once triggered you have to reset it Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted April 27, 2013 Author Share Posted April 27, 2013 Thanks Tdr and Rob, You guys rock. Sorted - Easy when you know how Link to comment Share on other sites More sharing options...
