1UZ-FE Conversion Aerotop Project
Guest BradD
Guest BradD
Thanks guys
Does anyone know what driveshaft setup I need?
I heard I need the front from the soarer and rear part from a supra. N/A or TT??
member called straightsix is your man for answers he built his a few years ago, Can a supra autobox be used instead of a soarer one? just curious as I was going to try this years ago but hate myself for never actually doing it.
member called straightsix is your man for answers he built his a few years ago, Can a Supra autobox be used instead of a Soarer one? just curious as I was going to try this years ago but hate myself for never actually doing it.
The TT box won't work because it has electronically controlled line pressure, and I'm not sure if the N/A version will work because, IIRC, the V8 'box has an extra solenoid (to smooth the gearchanges?).
Guest BradD
I want to keep the costs down to a minimum so will stick to stock box as much as I can. I'm not sure if the box is perfect but I'll see.
Never tested it when I bought the soarer but only worry was because the gearbox oil was pretty dark and there are lots of tiny particles of metal found on the filter.
If you rub your finger over you can see the miniscule pieces of what I could only think is worn gear metal?
  • 3 weeks later...
  • 3 months later...
Those miniscule metal particles would be in line with gearbox oil which has never been changed, Im sure it will be fine with new fluid....even without
The V8 is excellent as a daily, smooth, decent mpg and when the road does open up.....very fun.
ah okay, thats great. Was hoping it was something smaller like that rather the need for a complete replacement.
And yes I'm sure it'll be fantastic, really looking forward to completing this and getting it on the road :D
