Help : rear wheel sticking out - wishbones?
ray007
Hi all need some urgent advice
Just finished building a shell, instantly notice the right hand back wheel sticks out about 2 inches more than the left wheel?
Any ideas? From underneath everything looks ok, only thing I can think of is wishbones?
Any advice would be muh appreciated
Cheers
Edited by ray007 (see edit history)
The wishbone/s would have to be broken to let one wheel stick out 2.5" more than the other side, even
if you removed the bushes it wouldnt let the wheel out that much.
Is it out in toe or camber or both ?
As said already, pop some pics up
Loll.. Thanks for the input guys
Was just thinking about it and remembered the shell came with driveshafts but no diff. I believe it previously had a uk 6 speed diff and driveshafts and I use a w58/5speed LSD diff with the 6speed driveshafts... the driveshafts must be different lengths
So am I correct in saying the right hand driveshaft ok a uk 6speed is so much longer than from a w58 LSD dif?
And I think I did exaggerate on the inches, more like the right wheel is ticking out max 2inches mainly towards the rear of the wheel
The hub is held in place by the upper arm, lower arm no 1, lower arm no 2 and the strut rod, if you could
fit the wrong length drive shaft it shouldn't affect the position of the hub or how the wheel sits.
So what would be the effect of firing the wrong length driveshafts?
Drive shaft lenghts------R/H---------L/H
2JZ GE-----------------598.1-------552.2
2JZ GTE MANUAL------598.5-------547.5
2JZ GTE AUTO---------598.5-------553.5
The drive shaft wont work how it was designed to as the suspension moves up and down and
will cause problems in the cv joints.
I'd take the shafts off and measure them but as i said i don't see how this can affect where
the wheel sits as the hub is fixed apart from the adjustment you have for the camber and toe
