Identify these parts!
Kaan W
Ok so while stripping down my supra I keep coming accross things that I havent got a clue what they are. I like to know whats what and keep clutter to a minimum. Here is just some of the stuff I have cleared out [sHOCK][/sHOCK] -
The pictures below are things I need help from people to identify what it is and whether anyone else has this and if its needed or not ?
Part 1 - Located behind dash
Part 2 - Also behind dash
Part 3 - behind passenger side rear quarter plastics (has some sort of antenna).
Part 4 - Hanging loose in engine bay but still connected to part of the dash loom??
If anyone can help I would much appreciate it as I hate clutter and want to get rid of everything thats not needed. Thanks :)
Yeah just be careful when you remove it as it should also have a microphone and antenna unless you have taken them out already...
Oh ok. Can I remove the loom its not connected to the ecu or anything? Cheers
Yeah innovate wideband loom. If its not plugged into anything, out it comes.
The skinny wires on the other end were basically plugged into the afr gauge but the other chunky connector end, nothing. Dont know what that was suppose to plug into...
