Dnk Posted May 28, 2012 Share Posted May 28, 2012 (edited) I take it theres no issues with mixing differant brands of pre mixed antifreeze ? I cant get any Toyota Coolred as soon as i need it, i was going to top up a system that currently has Coolred in it with an ethylene glycol based alternative from the local motor factors Edited May 28, 2012 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
Dnk Posted May 28, 2012 Author Share Posted May 28, 2012 Any thoughts anyone ? Link to comment Share on other sites More sharing options...
David P Posted May 28, 2012 Share Posted May 28, 2012 Mix away, no prob. Link to comment Share on other sites More sharing options...
SteveR Posted May 28, 2012 Share Posted May 28, 2012 I understood therewere two main types, 'red' (which I guess is the ethylene glycol type) and 'blue'. I know that the wrong type can be damaging if used is it something to do with the block being aluminium/iron?? I also think it affects different types of pipework & seals?), but would I guess if they have the same stuff in them then mixing will be ok, but like you I'm guessing. My local motor factors are pretty knowledgeable, I'd ask yours and see if they sound believable enough to trust. Or if you're still worried, I think I've got an unopened 5l Toyota red in the garage you can have and then replace in slow time. Link to comment Share on other sites More sharing options...
David P Posted May 28, 2012 Share Posted May 28, 2012 Do a search, it has been asked before and given the all clear by C.W. Link to comment Share on other sites More sharing options...
Dnk Posted May 28, 2012 Author Share Posted May 28, 2012 Thanks for the replies guys, its actually for my car, i found a leak on the bottom hose and i've always used Coolred. Im kind of stuck at home as my landcruiser blew a rear diff seal so need to get something from a local supplier but thanks for the offer Steve The local Toyota dont carry it lol but have the Coolpink on the shelf but thats no good in the mkiv engine so im told. Link to comment Share on other sites More sharing options...
Robzki Posted May 28, 2012 Share Posted May 28, 2012 Most modern antifreeze is eth' glycol and can all be mixed fine, I think the 'colour change' stuff just has an additive to tell you to buy the expensive stuff. Link to comment Share on other sites More sharing options...
Dnk Posted May 28, 2012 Author Share Posted May 28, 2012 Theres not much in it price wise to be honest so thats not an issue Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 28, 2012 Share Posted May 28, 2012 The colour dose not denote the type, it just there so you can see it, there are two types, ·inorganic additive technology (IAT) ·organic additive technology (OAT) Inorganic Additive Technology This is the traditional coolant based on inorganic additives and is called inorganic additive technology (IAT). It is a tried and proven chemistry that provides a fast acting protective film. The additives deplete and the coolant needs to be drained and replenished every couple of years. This type can be used on all mixed metal engines with components including steel, cast iron, copper, brass, aluminium and solder without any detrimental effect. Organic Acid Technology The newer OAT coolants work differently from the older silicate based IAT coolants. Aluminium and ferrous metals form a surface-layer of corrosion in the presence of moisture, even with the little bit of moisture in the air. OAT coolants prevent this metal-oxide layer that protects the surface against this corrosion. Inherent with their design, the OAT coolants last longer than the older traditional IAT coolants. This category of antifreeze cannot be used in systems containing yellow metals. Link to comment Share on other sites More sharing options...
Dnk Posted May 28, 2012 Author Share Posted May 28, 2012 Drama over and i've tracked down 5 litres of coolred at another Toyota dealer. As always thanks for the input guys Link to comment Share on other sites More sharing options...
SamuraiFlash Posted May 28, 2012 Share Posted May 28, 2012 Damn it, I've just seen this now. I've got a 5ltr bottle of Toyota red here. I'm glad you got it sorted. Toyota world in Birmingham always have them in stock Link to comment Share on other sites More sharing options...
Dnk Posted May 28, 2012 Author Share Posted May 28, 2012 Damn it, I've just seen this now. I've got a 5ltr bottle of Toyota red here. I'm glad you got it sorted. Toyota world in Birmingham always have them in stock I havent got it yet if your coming over this way and would save me running the car in this rather hot weather with it being low on coolant Link to comment Share on other sites More sharing options...
SamuraiFlash Posted May 28, 2012 Share Posted May 28, 2012 I can bring it to the restaurant for about 6-6:30? Any good for you? Link to comment Share on other sites More sharing options...
Dnk Posted May 28, 2012 Author Share Posted May 28, 2012 Thats even futher for me to drive Kam so i'll get it from Toyota in Shirley Off topic Kam i have £15 for you, i forgot all about till now, i sold your Japfest tick in the que so you have a refund Link to comment Share on other sites More sharing options...
SamuraiFlash Posted May 28, 2012 Share Posted May 28, 2012 Ok dunk, i would have dropped it off to you before work if i wasn't looking after my son. Link to comment Share on other sites More sharing options...
Dnk Posted May 28, 2012 Author Share Posted May 28, 2012 Ok dunk, i would have dropped it off to you before work if i wasn't looking after my son. Not a problem mate, its not too far to walk in this searing heat im sure i'll make it if i take some water with me Link to comment Share on other sites More sharing options...
SamuraiFlash Posted May 28, 2012 Share Posted May 28, 2012 Lol, take a walk Dunk! It will put you in shape before your trip to Russia Link to comment Share on other sites More sharing options...
Dnk Posted May 28, 2012 Author Share Posted May 28, 2012 Lol, take a walk Dunk! It will put you in shape before your trip to Russia Lol yeh it'll probably finish me off more like, im not Bear Grills Link to comment Share on other sites More sharing options...
SamuraiFlash Posted May 28, 2012 Share Posted May 28, 2012 Lol yeh it'll probably finish me off more like, im not Bear Grills Lol!!! Let me know how you get on. Link to comment Share on other sites More sharing options...
stevie_b Posted May 28, 2012 Share Posted May 28, 2012 Good post by Tricky-Ricky. Do you know if OAT coolant is suitable in the supra? I don't recall any brass/copper coolant components. Link to comment Share on other sites More sharing options...
Robzki Posted May 28, 2012 Share Posted May 28, 2012 not too far to walk in this searing heat im sure i'll make it if i take some water with me Don't forget to put some antifreeze in it as it will act as a summer coolant as you know. Link to comment Share on other sites More sharing options...
Dnk Posted May 28, 2012 Author Share Posted May 28, 2012 Well i made it and the car is topped up and alls good again. Link to comment Share on other sites More sharing options...
SamuraiFlash Posted May 28, 2012 Share Posted May 28, 2012 Excellent news Dunk Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 28, 2012 Share Posted May 28, 2012 Good post by Tricky-Ricky. Do you know if OAT coolant is suitable in the supra? I don't recall any brass/copper coolant components. Not sure TBH, but hold on, is not the rad core copper? and is copper classed as a yellow metal? Link to comment Share on other sites More sharing options...
