new engine starts but wont rev up (photo added)
wewsupra
just brought a vvti engine and its now been put in the supra
gone to start it tonight and car starts but wont rev and cuts out
phoned keron and he has said have i got a air flow mass garage have checked and i have not got a vvti air flow mass
UPDATED brought a maf today from derby and now this is in place
car starts but wont rev up (engine keeps wanting to die every few mins )
any ideas
Edited by wewsupra (see edit history)
  • Replies 92
update ive got a maf from deby
ive put it on the car now
just started car and it took a bit of time to start but still the car wont rev any ideas please
would a leak cause this not to rev ,ecu not reset ect ect
ive not put air con rad back on car should i put this back on ? any help or advice needed please
local garage are doing the install and nope was not a vvti befor
Surely its up to the local garage to sort it, are they a MKIV specialist?
It could be any number of things, was new oil and filter replaced before starting, or the fluid levels all checked?
Does the throttle butterfly open and close when you press the accelerator? Get them to scpe the signal from the MAF sensor at the ecu. No throttle is usually MAF sensor or DBW throttle actuation trouble. Is the loom, engine, ecu and MAF sensor all matching? have they got facilities to check VVTi functionality? Not many garages have the slightest clue.
yes the butterfly opens and closers when pressing on the accelerator. The loom / engine / maf senors are all matching. The engine and loom and ecu came together.
The problem is after tonight - when starting up start first time its just like it wants to stall it self. after checking boost pipes / throttle butterfly / and making sure eall wireing loom is plugged in - it stil lwants to die - its like its misfiring and cuts out.
After is starts if you press the accelerator - its dies but some times if you on and off the accelerator quickly it will start to rev up but sounds very lumpy - like its missing firing. Tonight the garage got it going for about 10mins... revving up aswell... but didnt sound right at all... its was back firing and smoke was coming from the exhaust. also the cat started to glow red - which if im correct indicates over fueling ?
The over fueling can be the only thing i can think of now as its seems like its not to sure what it wants more air and less fuel or more air and less fuel.
To be hoenst i'm running out of idea's as i keep searching and searching what it could be / thoerys behind if its doing this then this must not be right etc etc ... i really dont know.
Did you connect the Blue-Red pin on the lower fusebox connector? If not, you have to do so. You can locate it on here.
http://www.mkivsupra.net/vbb/showthread.php?232824-J-Spec-Engine-Harness-Connector-Details&p=3030539&viewfull=1#post3030539
You will need to rework the fusebox and put a 15A fuse for this wire if you haven't.
Was the TPS removed or moved? If yes, it has to be adapted again.
First of all you will need to put it back in position. To do so, you will need to take a multimeter and connect to VTA and GND somewhere on the car. Rotate the TPS till you get 0.6-0.7V on cold engine (0.65-0.75V on warm engine) reading. You will find the VTA pin on here http://www.mkivsupra.net/vbb/showthread.php?232824-J-Spec-Engine-Harness-Connector-Details&p=3277822&viewfull=1#post3277822
Then put the turn key to ON without starting the car and hit the acceleration pedal to the floor, keep it that way for 30s to a min. You will hear a buzzing sound. Your TPS will adapt to the ECU. Then turn the key to off and then start the car. Btw make sure to clean the throttle butterfly REALLY WELL before doing all this.
Also check the coils for oil/water and if they are connected properly. They are pretty tricky. Of course you have to check the condition of the spark plugs.
Check these and tell me if there is any result.
Edited by EMPEROR (see edit history)
There was 2 plus from the main fuse box that plug into the engine loom. One fits perfect but you have hard wire the other one
we have done this and car starts ok now and is running and holding revs
on little test run the car wont rev above 3k revs and bottles out
so now we are going to make sure maf and induction hard pipe and kit is all tight and secure
as could this be the problem
Hi mate when i did my engine change to the vvti I had to have it tuned to get it to run right but I had auto ecu and had a new helteck ecu with maps and stuff
And my vvti tb is a fly by wire not dbw
Are u 100% sure it's a dbw not a fbw
Thanks Luke
