Nodalmighty Posted June 5, 2012 Author Share Posted June 5, 2012 This is how I do the fog light on JDM : http://www.nod-land.co.uk/assets/images/FogLight1.jpg Diodes stop fog light and foot brake signals clashing but allow them to work independently. http://www.nod-land.co.uk/assets/images/FogLight2.jpg A lot easier than the relay method and achieves the same goal. I'm going to connect the rear fogs to the front fog light switch on the light stalk as I don't want random switches all over my dash. My new front seats, I needed to cut the carpet out to sink my new sub amp low enough to clear the seats. http://www.nod-land.co.uk/assets/images/NewSeats1.jpg http://www.nod-land.co.uk/assets/images/NewSeats2.jpg I'm going to have my OEM steering wheel, handbrake and auto selector clothed in the same manner (hopefully my those nice chaps at the Morgan factory in Malvern ) I also fixed my drivers side sill panel and installed new Alpine speakers in the rear. The OEM ones had crumbled into nothingness and all the rubber had disappeared so the paper cones were floating in mid air. I still can't believe they even made a sound let alone play music. Lyndon. Quote Link to comment Share on other sites More sharing options...
Supra-duper Posted June 5, 2012 Share Posted June 5, 2012 Looking good mate, if your ever passing my house and I'm about on the drive feel free to pop in. You'll know it instantly, the house on the Walsall Road with the big yellow Supra on the drive and a oil covered bloke looking clueless underneath it Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted June 5, 2012 Share Posted June 5, 2012 Looking good, any more details on the diodes etc you use for the fog light conversion? I'd seriously consider dyeing your carpet black while you're fitting the amp, it's a huge improvement. Quote Link to comment Share on other sites More sharing options...
lexmk4 Posted June 5, 2012 Share Posted June 5, 2012 this is going to be fun Quote Link to comment Share on other sites More sharing options...
Nodalmighty Posted June 6, 2012 Author Share Posted June 6, 2012 (edited) Looking good, any more details on the diodes etc you use for the fog light conversion? I'd seriously consider dyeing your carpet black while you're fitting the amp, it's a huge improvement. Carpet is not worth doing it's to far gone. Diodes are just 1N4004, nowt special. Lyndon. Edited June 6, 2012 by Nodalmighty (see edit history) Quote Link to comment Share on other sites More sharing options...
Nodalmighty Posted June 7, 2012 Author Share Posted June 7, 2012 Just bought a 90mm Billet TB, well i like to snap up a bargain when they present themselves (£55 delivered) and the colour matches the bearing housing on my turbo I shall have fun adapting the cruise control to use that monster Fortunately I'll be running a TT auto box so no line pressure cable required. Lyndon. Quote Link to comment Share on other sites More sharing options...
FOSTA Posted June 7, 2012 Share Posted June 7, 2012 Nice bit of kit mate! Where did you purchase this bad boy from? Quote Link to comment Share on other sites More sharing options...
Nodalmighty Posted June 7, 2012 Author Share Posted June 7, 2012 Off the MK3 forum, some chaps breaking his Turbo Manual and selling his project bits off. Lyndon. Quote Link to comment Share on other sites More sharing options...
Noz Posted June 7, 2012 Share Posted June 7, 2012 That does look tasty. Where you going to relocate the sensors from the oem TB? Quote Link to comment Share on other sites More sharing options...
Nodalmighty Posted June 7, 2012 Author Share Posted June 7, 2012 (edited) That does look tasty. Where you going to relocate the sensors from the oem TB? Do you mean the TPS and the idle control valve? OEM TPS should fit straight on (but I have various others should that not be the case). Idle valve is going to be replaced with twin Bosch PWM idle valves as I'll be running ALS and a K6 ecu. Lyndon. Edited June 7, 2012 by Nodalmighty (see edit history) Quote Link to comment Share on other sites More sharing options...
Nodalmighty Posted June 12, 2012 Author Share Posted June 12, 2012 (edited) I've bought a pair of SRD's front speaker brackets to fit my Alpines. Not before time looking at what is left of the old OEM speaker. http://www.nod-land.co.uk/assets/images/FrontSpeaker.jpg lol I've also bought a JBL 8" sub as I suspect the OEM woofer has suffered a similar fate. Lyndon. Edited June 12, 2012 by Nodalmighty (see edit history) Quote Link to comment Share on other sites More sharing options...
Noz Posted June 12, 2012 Share Posted June 12, 2012 Good plan with the speaker pods, I also need to sort out my sounds. Does this make the NA-T conversion faster through sound power Quote Link to comment Share on other sites More sharing options...
Nodalmighty Posted June 18, 2012 Author Share Posted June 18, 2012 Did the full blue led conversion on my dash at the weekend. Blue back lights for dash, heater, ignition ring, ciggy ring, auto selector and ash tray. LED conversion for heater and dark blue film conversions for indicators, clock and odometer. Clock looks a bit gash but the rest is ok (not that this bothers me as the clock is being replaced with one of my TFT billet gauges in the near future). I used super Bright LEDS in the heater and they are bit much so a resistor conversion will need to be done to balance the bright v's dim ratio. Very nice conversion otherwise, however, I did forget how fiddly the heater ecu is to take apart Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted June 18, 2012 Share Posted June 18, 2012 Pictures That speaker made me laugh, did it actually make any noise?? Quote Link to comment Share on other sites More sharing options...
Nodalmighty Posted June 18, 2012 Author Share Posted June 18, 2012 Pictures That speaker made me laugh, did it actually make any noise?? I have no pictures. Just imagine a dash when everything that was one green or yellow is now blue It does actually work but doesn't half crackle when you chuck some bass at it . My rears were exactly the same, only the sub is still intact. Alpine SXE 17's all round soon as I should have SRD front speaker brackets today hopefully. I have my 8" JBL sub in stock and need to make a enclosure for it (passenger side of the spare wheel looks good as there isn't anything there currently). Lyndon. Quote Link to comment Share on other sites More sharing options...
Nodalmighty Posted June 19, 2012 Author Share Posted June 19, 2012 SRD speaker brackets in stock. They look a quality item. Can't wait to get them fitted at the weekend Lyndon. Quote Link to comment Share on other sites More sharing options...
Guest vasee13 Posted June 19, 2012 Share Posted June 19, 2012 post pictures of your dash pleasee:eyebrows: Quote Link to comment Share on other sites More sharing options...
Suprash Posted June 20, 2012 Share Posted June 20, 2012 Subscribing Nitrous just used to help spooling ? Interested to hear advantages in this area/gains ? Quote Link to comment Share on other sites More sharing options...
Nodalmighty Posted June 28, 2012 Author Share Posted June 28, 2012 Subscribing Nitrous just used to help spooling ? Interested to hear advantages in this area/gains ? I'm not fitting Nitrous, been there, done that, complete waste of money. Lyndon. Quote Link to comment Share on other sites More sharing options...
Nodalmighty Posted June 28, 2012 Author Share Posted June 28, 2012 I've now fitted the SRD speaker brackets and Alpines in the front. http://www.nod-land.co.uk/assets/images/speaker2.jpg http://www.nod-land.co.uk/assets/images/speaker1.jpg Sounds so much better now and they officially passed the Prodigy test. Lyndon. Quote Link to comment Share on other sites More sharing options...
Nodalmighty Posted July 9, 2012 Author Share Posted July 9, 2012 Finally finished the ICE install. JBL 8" sub in a £10 ebay special sub box. http://www.nod-land.co.uk/assets/images/jbl1.jpg http://www.nod-land.co.uk/assets/images/jbl2.jpg Again, Prodigy test passed with flying colours. Lyndon. Quote Link to comment Share on other sites More sharing options...
