Auxiliary pulley torque ?
JMB
So!
For the alternator pulley :
4. INSTALL PULLEY
(a) Install the pulley to the rotor shaft by tightening the pulley nut by hand.
(b) Hold SST (A) with a torque wrench, and tighten SST (B) clockwise to the specified torque.
SST 09820–63010
Torque: 39 N·m (400 kgf·cm, 29 ft·lbf)
© Check that SST (A) is secured to the pulley shaft.
(d) Mount SST © in a vise.
(e) Insert SST (B) into SST ©, and attach the pulley nut to
SST ©.
(f) To torque the pulley nut, turn SST (A) in the direction
shown in the illustration.
Torque: 110.5 N·m (1,125 kgf·cm, 81 ft·lbf)
(g) Remove the generator from SST ©.
Power steering pulley . 2JZ–GTE:
INSTALL SUCTION PORT UNION
(a) Coat a new O–ring with power steering fluid and install it to the union.
(b) Torque the bolt.
Torque: 13 N·m (130 kgf·cm, 9 ft·lbf)
