Dnk Posted February 16, 2012 Share Posted February 16, 2012 I charge from when i start the job not when the cutter touches the material Excluding the carrying to the machine part, i'll throw that in for free Also i think this could vibrate like a vibrating thing so it might not be that straight forward depending on how you can clamp it. Quote Link to comment Share on other sites More sharing options...
Noz Posted February 16, 2012 Share Posted February 16, 2012 could you not just hold it with a guy either side? Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 16, 2012 Share Posted February 16, 2012 could you not just hold it with a guy either side? Did you forget the smiley ? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 16, 2012 Share Posted February 16, 2012 Clamping up a split face manifold is not exactly straightforward, they can be a nightmare to clamp rigidly. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 16, 2012 Share Posted February 16, 2012 could you not just hold it with a guy either side? As in bloke either side with big muscles, guy ropes, or what? Good idea though.... Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 16, 2012 Share Posted February 16, 2012 Clamping up a split face manifold is not exactly straightforward, they can be a nightmare to clamp rigidly. The only way really would be to machine them seperately and just take the same amount off each side. I doubt it would fix the issue though if they've warped already then making them even thinner isn't going to help. Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted February 16, 2012 Author Share Posted February 16, 2012 Well had play like said and checked manifold flanges and the rear flange is warped by half a mill and is also 1 mill thiner than the front flange, am going to fit standard back on friday as want use of my car back. understand about the extra tension on head studs as when fitted it for the 1st time had to pull exhaust abit to line up with the manifold downpipe. Am going to take the stainless manifold to local machine shop and get both flanges milled the same thinkness so that then are perfect and smooth and will try refit the stainless manifold in couple weeks again. remember someone saying about a thicker gasket aswell any idea where i can get them from please? also when the manifold is fitted will i be able to weld some tension rods onto manifold to help? if not is it worth having it done before refit? really do want to keep stainless manifold and get it fitted spot on, i know it can warp again but am looking at getting tt lump fitted start next year maybe end of this year. just mainly want stainless manifold fitted for this year so can enjoy the shows plus improve performance on car. Quote Link to comment Share on other sites More sharing options...
