Slam Posted October 21, 2011 Share Posted October 21, 2011 Right i decided to have a go at cleaning my engine bay today,hoping to get to polish the black painted area's,& plastic's ect. My fist problem is somone had sprayed some sort of engine laquar around the hole bay.which has left a hard layer over everything:eyebrows: Can anyone advise on how to remove,as i was scraping the skin with a bit of plastic, this was stressfull[ANGRY][/ANGRY] Help from the valleters would be greatfull. Quote Link to comment Share on other sites More sharing options...
TT Paul Posted October 21, 2011 Share Posted October 21, 2011 brake cleaner? Quote Link to comment Share on other sites More sharing options...
Slam Posted October 21, 2011 Author Share Posted October 21, 2011 (edited) Just looked at the your post again mate & edited myself. Edited October 21, 2011 by Slam (see edit history) Quote Link to comment Share on other sites More sharing options...
Slam Posted October 21, 2011 Author Share Posted October 21, 2011 Do i use a per what it says on the tin Quote Link to comment Share on other sites More sharing options...
hodge Posted October 21, 2011 Share Posted October 21, 2011 Use Valvoline engine degreaser it amazing stuff. It will remove all the oil and dirt that's added up over the years. Quote Link to comment Share on other sites More sharing options...
Josh Posted October 21, 2011 Share Posted October 21, 2011 Do i use a per what it says on the tin If it says use gloves, yes. Quote Link to comment Share on other sites More sharing options...
Slam Posted October 21, 2011 Author Share Posted October 21, 2011 Just need to make sure that you all understand what the problem is, it is not dirt,grease,engine oil, It is not just the three said,but a spray over protector which i want to remove. Quote Link to comment Share on other sites More sharing options...
Slam Posted October 21, 2011 Author Share Posted October 21, 2011 Dose the brake cleaner break-down this skin? Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted October 21, 2011 Share Posted October 21, 2011 see if you can put a pic up bro might help. The valvolene one hodge says may work, Its like a varnish thats somebody has sprayed over the engine yes ? Quote Link to comment Share on other sites More sharing options...
Slam Posted October 21, 2011 Author Share Posted October 21, 2011 Yes bro varnish. i wanna remove it. Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted October 21, 2011 Share Posted October 21, 2011 i got some degreeser in unit to try maybe sunday Quote Link to comment Share on other sites More sharing options...
Slam Posted October 21, 2011 Author Share Posted October 21, 2011 Its over the arches,air filter box,front top panel,top of radiator,most places. Quote Link to comment Share on other sites More sharing options...
TT Paul Posted October 21, 2011 Share Posted October 21, 2011 jizer degreaser? Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted October 22, 2011 Share Posted October 22, 2011 All purpose cleaner? Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted October 22, 2011 Share Posted October 22, 2011 white spirit? i know the stuff your on about, horrible gear Quote Link to comment Share on other sites More sharing options...
Slam Posted October 22, 2011 Author Share Posted October 22, 2011 sounds like a plan,will try a patch today.white spirit? i know the stuff your on about, horrible gear Quote Link to comment Share on other sites More sharing options...
Slam Posted October 22, 2011 Author Share Posted October 22, 2011 Well we went around the engine bay with white spirit,& it works,takes a bit of time,but we are getting there. Quote Link to comment Share on other sites More sharing options...
DodgyRog Posted October 22, 2011 Share Posted October 22, 2011 It always takes time to clean under the hood properly, but that stuff looked nasty to remove, looks like your getting there though I will proberbly spend most of tomorrow doing mine as I have not touched it since before all the bodywork was done. So there loads of rub down dust and crap every where under there:taped: Quote Link to comment Share on other sites More sharing options...
Slam Posted October 22, 2011 Author Share Posted October 22, 2011 A big thanks to mine scruber in crime,Karen(wife) This chapter continues as you say Rog. Quote Link to comment Share on other sites More sharing options...
Stonkin Posted October 24, 2011 Share Posted October 24, 2011 Sorry for a late reply to your pm mate, its been a manic w'end. Looks like you are making good progress Doing an engine bay isnt always simple when you see what some people have applied in the past to protect things. The wax that Subaru normally apply is awful stuff, yes it does the job but looks blimin naff. I would keep going as you are and follow it up with a good scrub of warm water, all purpose cleaner and an angine and machine cleaner with brushes. Finally dress everything whilst its still wet with some aerospace 303. As you are NA just take care not to get water when rinsing around the cam valleys where the plugs sit. Quote Link to comment Share on other sites More sharing options...
Slam Posted October 25, 2011 Author Share Posted October 25, 2011 Sorry for a late reply to your pm mate, its been a manic w'end. Looks like you are making good progress Doing an engine bay isnt always simple when you see what some people have applied in the past to protect things. The wax that Subaru normally apply is awful stuff, yes it does the job but looks blimin naff. I would keep going as you are and follow it up with a good scrub of warm water, all purpose cleaner and an angine and machine cleaner with brushes. Finally dress everything whilst its still wet with some aerospace 303. As you are NA just take care not to get water when rinsing around the cam valleys where the plugs sit. Thanks for your reply. Quote Link to comment Share on other sites More sharing options...
