My single project
_Shane_
Well i said its time to start a little project thread on my supra. As most of you know i sold on my R34GTR and got myself another Supra
This supra is a 1995 Jap spec with a bn sports kit and veilside wheels, 6 speed box and 96k klms on the clock
Car came with coilovers, fmic, exhaust, downpipe / decat etc
Apexi avcr, neo and rsm and oil pressure gauge
Will try to update this as much as possible
The aim is hopfully 550-600 bhp
Car will be having work carried out by SSI up northern Ireland and I will be asking Ryan G to map it :)
Stock cloth seats came out first along with the carpet as i wanted to dye the carpet black. Dash panels out to make way for the carbon ones that i got from Dave on here (thanks mate)
Bit of a disaster removing the driver seat as the electric motor was broken and the seat would not slide forward so i was unable to get at the back 2 seat bolts, eventually got it sorted but it was a total pain in the a$$
headlights removed as they are going to be sent for a refurb as the plastic is a little dull
carpets were dyed and i must say i am very very pleased with how they turned out :) completely finishes off the interior of the car now :)
while the carpets were out i rewired all the apexi gauges and re-routed the cabling in behind the dash
some more bits started to arrive then bit by bit
Power house racing stage 2 turbo kit (thanks for RobD)
PHR DBB turbo - polished housing
HKS manifold
HKS external wastegate
PHR downpipe
PHR midpipe
PHR oil/water lines
Greddy bov
PHR air filter and intake piping
PHR hard piping from turbo to fmic (hot side)
52mm aluminium radiator
samco blue rad hose kit
Alpine mp3 head unit
Toyota iso adaptor
single din pocket
Leather handbrake gaitor
Leather gear surround
Titanium burnt gear knob
new pedals to replace the crap that was in it
Carbon dash panels
chrome cigarette lighter ring surround
chrome digital clock ring surround
chrome air vents rings
chrome heater rings
car now up on axle stands and had the veilside wheels removed for a good clean. These will be going for a refurb also
the carbon dash
will have better pics when its all put back together
Also got a carbon fuse box for under the engine bay, will get a pic of that uploaded soon
Inside then i had standard cloth supra seats;. These had to go. Got a set of black suede Recaros with red stitching and custom made rails and these fitted in nicely with the new interior
Interior should be back together this weekend, just waiting on a new apexi turbo timer to arrive, hks turbo timer harness is fitted so it just needs the turbo timer and we are good to put all the dash back together
stay tuned for some more updates :)
Once engine is finished car is going for a full respray
good luck with it mate, youve got a big task on your hands making it nicer than that r34 you had that was a beauty!
True mate lol but at least i will be using the Supra, the GTR was just an expensive bit of art sitting in my garage
good price! looks great looks to have covered very well.
ebay i think £20 mate, only reason i didnt buy from there was postage costs
If ya lived close mate you could take a liter of my stuff :) so easy to do and looks completely new when finished
I know what you mean, good job with the carpet just did mine really easy and cheap to do and makes such a difference to the interior
  • 1 month later...
***Car was dropped of with Colin & Marty @ SSI last Wednesday for the work to commence :)***
All interior is back in and im very happy with the new look
Fuel System purchased form Ryan G
WOTM customised fuel hanger
Twin Walbro fuel pumps
Fully custom fuel pump wiring (With individual fuses and ECU controlled relays)
Aeroquip Startlite -6 hose inside tank fuel.
Aeroquip fuel hanger bulkhead fittings
Customised fuel tank cover
Aeroquip -8 racing hose fuel feed
Aeroquip fuel filter
Jiffy-tite -8 dry break fuel filter fittings
Twin Aeroquip -6 racing hose fuel rail feeds
Power House Racing fuel rail
Siemens 870cc cleaned and balanced low impedance injectors
Aeroquip -6 racing hose fuel central fuel return
Aeroquip fuel pressure regulator
A-TEK -2 fuel pressure reference hose
Jiffy-tite -6 dry break fuel pressure regulator fittings
Aeroquip -6 racing hose fuel return hose
Aeroquip Startilite -6 fuel tank breather hose.
Custom made carbon fibre fuel hose mounting brackets.
With ATek quick release fittings. Make fitting easy
Even has carbon brackets for fuel lines
pic of the what the turbo kit looks like from PHR website and few comments on what they say about the kit
http://www.mvpmotorsports.com/Merchant//catalog/jdm/t/supramkiv/p/phr/phrtk5s.jpg
The kit includes:
Polished PHR Turbocharger
HKS Genuine (not a knock-off like used in the Sound Performance or Boost Logic kits) Stainless Steel Tubular 50mm Single Turbo Header
HKS GT Series Wastegate
High-temp heat coating on the manifold, downpipe, midpipe, turbo exhaust housing, and dump tube
3" Steel Downpipe, Dump Tube, & 3" Midpipe (all heat coated).
The Downpipe & Midpipe all have 3" V-bands making installation a breeze.
All other brands of turbo kits use (much) cheaper flanges which always have a hard time matching up perfectly. A V-Band is circular allowing you to rotate the Downpipe in virtually any direction necessary which makes everything much easier, cleaner, and does not put stress on your turbo exhaust housing
Custom made (not generic) & powder coated intercooler piping specific to your intercooler. Also this is the only piping on the market that goes direct from your FMIC to your Turbo without going through the fender. What this means to you is it is easier to install and more importantly a more direct route with less bends, thus making more power
4" Mandrel Bent Air Intake Piping, Powder Coated
4" K&N Air Intake
All Stainless Steel Teflon Braided Lines with Earl's Fittings
All Fittings, Hoses, Bolts, Filters, etc. Included
http://www.mvpmotorsports.com/Merchant/phr_turbo1.jpg
new rad fitted before we went up north, car running perfectly. Also fitted new blue samco hose kit
