w41k3r Posted April 17, 2011 Share Posted April 17, 2011 just seen this on supraforums might be a cheap alternative to the xs power one and should be by the look of it less clearance issues http://www.treadstoneperformance.com/product.phtml?p=1865 Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 17, 2011 Share Posted April 17, 2011 (edited) Why oh why do these people make such a small wastegate hole periphery? It's asking for a gasket blow out, they should have made the land area much wider, and three bolt. Hopefully the material spec will help negate any distortion. I would love to see one in the flesh. It sure is looking like it will be a lot more reliable than the Chinese tubular stuff. I wonder if there are any issues on a RHD car? Edited April 17, 2011 by Chris Wilson (see edit history) Link to comment Share on other sites More sharing options...
Biguns Posted April 17, 2011 Share Posted April 17, 2011 Looks good may be tempted to go na-t now Link to comment Share on other sites More sharing options...
w41k3r Posted April 17, 2011 Author Share Posted April 17, 2011 i think it works out around £250 maybe less so if it is decent it might be worth the chance it should help with clearence issues though and i know you cant tell on the pics but it also looks like it shouldnt have dizzy issues either Link to comment Share on other sites More sharing options...
Wez Posted April 17, 2011 Share Posted April 17, 2011 If I was doing an NA-T I would look at something like that and possibly weld/seal up the wastegate port and look at a small internally gated turbo Link to comment Share on other sites More sharing options...
w41k3r Posted April 17, 2011 Author Share Posted April 17, 2011 wez that is a very good idea that would deffo keep it very simple Link to comment Share on other sites More sharing options...
johnny g Posted April 17, 2011 Share Posted April 17, 2011 If I was doing an NA-T I would look at something like that and possibly weld/seal up the wastegate port and look at a small internally gated turbo Yea, a nice GT3071R would be perfect for that - super spool as well. Link to comment Share on other sites More sharing options...
j_jza80 Posted April 17, 2011 Share Posted April 17, 2011 It's designed for a vvti 2jz-ge, would it still work? Link to comment Share on other sites More sharing options...
Nic Posted April 17, 2011 Share Posted April 17, 2011 It's designed for a vvti 2jz-ge, would it still work? Doesn't look like it would fit a non-VVTi with a distributor. Link to comment Share on other sites More sharing options...
Kirk Posted April 17, 2011 Share Posted April 17, 2011 I dunno i think you might just get away with it tbh. It does sit quite low and central to the head. Be worth a try, either that or find yourself a VVTI GE Link to comment Share on other sites More sharing options...
Nic Posted April 17, 2011 Share Posted April 17, 2011 I dunno i think you might just get away with it tbh. It does sit quite low and central to the head. Be worth a try, either that or find yourself a VVTI GE Also depends if the bolt pattern is the same of the VVTi Link to comment Share on other sites More sharing options...
Kirk Posted April 17, 2011 Share Posted April 17, 2011 True! Interesting to find out as the vvti ge's have a very different style of manifold compared to non. http://home.roadrunner.com/~bedellracing//v8swap/sportcross4.jpg Link to comment Share on other sites More sharing options...
j_jza80 Posted April 17, 2011 Share Posted April 17, 2011 Be worth a try, either that or find yourself a VVTI GE At first I thought that was ridiculous, but actually a vvti NA-T conversion would have some pros. The wiring would probably be a PITA, but replacement engines would be cheap and plentiful, and it would most likely make for a very responsive setup with decent economy. Hmmm... I'd still rather a good tubular manifold though, someone pointed out not so long ago how crap log manifolds sound compared to tubular, quite a difference. Link to comment Share on other sites More sharing options...
