luisito-awo Posted April 4, 2011 Share Posted April 4, 2011 hi guys i got an 2jzgte engine with an damaged block.. but i also have a 2jzge ( n/a ) engine... ive done different researches and found out that the block,crank and rods are the same but i doesnt have oil squirters like the 2jzgte's block... my quistion is what about the pistons? are they the same? are they stronger/weaker then the 2jzgte ones? and can i just bold my 2jzgte's head on the 2jzge block? thx Link to comment Share on other sites More sharing options...
Nic Posted April 4, 2011 Share Posted April 4, 2011 The pistons are different on the 2JZ-GE and 2JZ-GTE Link to comment Share on other sites More sharing options...
mwilkinson Posted April 4, 2011 Share Posted April 4, 2011 With regards to the engine block (I appreciate you were asking about pistons) I think Chris Wilson has been looking to get hold of a scrap gte block and ge. He intends to cut them up to see once and for all if the gte block has different coolant passages, hence different casting than the ge block. This something you may also be interested in. Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 4, 2011 Share Posted April 4, 2011 A friend is sending me detailed photos of a chopped up TT block, I am up for buying a damaged N/A block to cut up if anyone has one? Link to comment Share on other sites More sharing options...
dude Posted April 4, 2011 Share Posted April 4, 2011 I have one you can cut up Chris, I need the crank out of it. Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 5, 2011 Share Posted April 5, 2011 OK, that's great. How much? Is there any chance you can stick it on a half pallet and I'll get it picked up? Link to comment Share on other sites More sharing options...
dude Posted April 5, 2011 Share Posted April 5, 2011 OK, that's great. How much? Is there any chance you can stick it on a half pallet and I'll get it picked up? I'll donate it in the interests of Supra Science Chris, I just need the crank out and we are mega busy at the moment. Link to comment Share on other sites More sharing options...
David P Posted April 5, 2011 Share Posted April 5, 2011 (edited) hi guys i got an 2jzgte engine with an damaged block.. but i also have a 2jzge ( n/a ) engine... ive done different researches and found out that the block,crank and rods are the same but i doesnt have oil squirters like the 2jzgte's block... my quistion is what about the pistons? are they the same? are they stronger/weaker then the 2jzgte ones? and can i just bold my 2jzgte's head on the 2jzge block? thx T.T. pistons are different, they give lower compression, but stock diameter T.T. pistons will fit into stock bore diameter N/A block. Yes the T.T. head will fit onto the N/A block. Edited April 5, 2011 by David P (see edit history) Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 5, 2011 Share Posted April 5, 2011 No rush, just let me know and I can arrange collection. Will share the results Link to comment Share on other sites More sharing options...
dude Posted April 10, 2011 Share Posted April 10, 2011 No rush, just let me know and I can arrange collection. Will share the results Its all stripped Chris, just need a pallet to put it on. Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 11, 2011 Share Posted April 11, 2011 OK, great just let me know John, cheers. Link to comment Share on other sites More sharing options...
