q45 throttle body
davep
Greddy intake was built to take a Q45, you also need the TPS kit, part number 13910400.
Q45 comes from a Nissan Infiniti.
Infiniti is fly by wire jamie, Q45 is from Z32 and Centra, IE earlier models, you wouldn't be able to use the later ones unless you add all the electronics and stepper motors.
I bought mine being advertised as a Infiniti Q45, maybe some never had dbw?
Do you need, or even want a bigger throttle plate area though? Two cheap boost gauges plumbed just before and just after the throttle plate on a stock set up will easiliy show if there's a meaningful pressure drop across it and it could do with being bigger. Needlessly increasing throttle plate area can give a trigger like low throttle opening response, and the the top third of the throttle travel doing little if anything at all. In conditions of low traction (he says looking out the window....) a linear and stable throttle response is very very desirable.
