Anybody done the r154 conversion on a tt.
Baz018
  • Replies 153
Posted Images
well i could be swapping my w58 for a R154.
But is it more hassel then it is worse, Does the prop shaft need modifying,
will it fit the w58 mount,
I know the shifter needs extending but i have found a company that makes them.
I'm in the process of fitting a R154 with a TT engine to my NA, you'll need a 1jz bellhousing 7mgte ( I think ) clutch and fly wheel, the front half of a R154 prop and rear half of a w58, slave from a r154 and the shifter extension!
What sort of price can you get the shifter extension done for? :)
there are people in the uk who will do the shifter for less, you just need to tell them how long you want it extending... i think you need the 7m prop mated with the mkiv prop. which could probably be where the 2" thing is from...
i know where you can get the bellhousing from if you need one
I got 3/4 there (i.e bought a R154 and bellhousing + prop), then decided it wasn't significantly cheaper than 6 speeda nd went the 6 speed route.
These are the costs:-
Used R154 £350
Bellhousing 31111-14110 £300 (based on buying new from Toyota with 15% discount)
Driftmotion actually works out more expensive with the current exhange rate and shipping
Light weight flywheel as I can’t find a stock one to buy £300 DW
Clutch DW Spec 3 £400
Slave cylinder 31470-14050 61.09 (Again try finding a used one)
Flywheel bolts 90910-02103 8 off £54.56
Clutch release bearing 90363-45012 or 31231-14040 £21.85
Sub Total £1487.50
Then to correct the shifter position
Shifter Fork 31204-14031 51.86
Shifter housing 33521-24040 19.52
Control lever 33570-24010 76.14
Total = £1635 then you need a custom prop making which will be approx £150 + the R154 joint
So its only worth doing if you can buy a used kit of bits which includes the main bits as you would still be missing the pedal and clutch master cylinder.
It makes 2.5K for a 6 speed seem more reasonable
Mate, just go to Toyota, stock flywheel is 170 quid, and I can give you an ebay link for a non gen bellhousing, 211 quid with free postage from Malasia.
Steve we need to discuss shifter extensions and filters :)
Still doesnt make it cheap, can you post the ebay link as I may do a 1JZ to JZ and would use R154 if I can get the bit cheap enough.
I have all the toyota part number if your interested
No its not cheap but its almost half the price of the Driftworks item and its OE quality :)
Ive got the numbers for the Toyota bellhousing but cheers anyway.
Heres the link for the cheapy cheapy :-
http://cgi.ebay.com/ebaymotors/1jz-gte-2jz-gte-toyota-Supra-Bellhousing-r154-FREE-SHIP-/280563830286?pt=Motors_Car_Truck_Parts_Accessories&hash=item4152e84e0e#ht_500wt_1182
Rob, the cradle looks similar but not sure about the gear selection rod into the gearbox. I recently sold a W58 and looked at that myself.
no i know it wont put 3 on but would a r154 make any differance at all?
What im saying is a r154 will cost about 1500 to convert where as the 6 speed is about another grand but surely the car will be worth a grand more. I would sell my car for 5 grandish now so must be worth more with a getrag.
Not that im ever planning on selling it as there is no other car i want.
Yeah of course it would, theres not many 6 speeds about, and even less R154s. Most drivers prefer manual over auto boxes so it will be worth more than an auto to the right person :) As Ive said before Id urge any prospective 6 speed buyer to drive a car with the box in first.
Oh and FWIW the parts for the conversion to 6 speed are 2.5km thats minus labour. My 5 speed swap will bearly break a grand
